Woodcraft 8" grinders
Jamie Donaldson
>The Woodcraft 8" grinders are the best value for most turners, but almost all benefit from a tune-up right out of the box. Many of the AlO wheels have a wobble that is due to several factors, including stamped rather than machined flanges, erratic centering due to sloppy plastic spacers, and variations in wheel density and dimensions. Most of these problems can be improved by placing an index mark on the wheels, loosen the nuts slightly, and rotate inch by inch until the wheels run more true, then tighten the nuts. Wheel wobble is both difficult and potentially dangerous to eliminate by dressing the sides of the wheels,and once the wobble is gone then the faces of the wheels can be dressed true by conventional methods.
Re: Woodcraft 8" grinders
Mike Stafford
Mike Stafford
>Jamie, I have only had any prolonged experience with Woodcraft grinders at JCCFS and with one of my friends who bought one.
I have to say my experience has been that they don't run true for very long and virtually every time I have gone back to the wheel it needed to be dressed again because the edge of the wheel does not seem to run in the same plane.
I have very little to say good about these machines but perhaps I have not seen one properly trued up and running correctly.
I am spoiled in my shop because I have a Baldor 8" that I owned long before I started turning and all I had to do was get some new wheels.
>I've had one of the Woodcraft slow speed grinders for 4 or 5 years now and it runs perfectly. The only downside has been when installing new wheels I have to spend a little time aligning them. I would buy another one in a heartbeat.
Dave Anderson (PacNW)
>I have the fore mentioned grinder. I was not very happy with it until I stepped up and bought the Norton 3X "K" bond wheels and a Oneway wheel balancing kit. It now runs smooth as glass. The cost cost of the grinder, new wheels and the kit are still a lot less than a new Baldor grinder
Re:Mike- your experience with the Folk School....
Jamie Donaldson
>...grinders is an accurate observation of severe grinder abuse! Most Woodcraft grinders are not stressed to the MAX as are those, and a private owner/user should receive many years of good use from these grinders. I have both 6" and 7" Baldors, and equipped my 6" with 1"wide wheels when the 7" wheels were worn down enough to fit. Phrugal!!
