The STATIC Display Thing - Again
charlile belden
>Until relatively recently, turned objects have been done to be diplayed - static - fixed - the viewer having to walk around the piece to change the viewing angle. Oh - and they're silent. The piece just sits there, quietly
Magazines and most online galleries impose even more static limitations - one photo, perhaps two - still photos - static - fixed - silent.
But people have been doing dynamic pieces - pieces that actually move, or are intended to be moved, and/or make noise unassisted - or with the help of the "viewer" - for a while now. But the available impressions of these pieces through still photos is a mere shadow of the piece and can't hint as to what's not being conveyed.
Take one of Hunter's pieces - with the spiralling carved "fingers". Still, the piece is interesting. But rotate it and what you see and experience is significantly expanded by the interaction of of the "far side" and "near side" spiraling "fingers".
I've been playing (and I mean playing because it's fun) with incorporating actual movement in pieces
- a dragon fly with wings that vibrate as the insect hovers over the end of a twig, a puff of air causing it move
- a stack of turned little jugs - joined by fine spring wire which allows elements of the column to jiggle as some one walks by, or touches any of the jugs
- a lidded "hyper ellipsoid" box which rocks a little when touched - a pendulumn finial on the top which always remains vertical, regardless of how the box beneath it is tilted.
- a little hammer connected to a base with a nail in it by a little spring steel wire - "hammers" when touched, bouncing up and down.
and most recently
- the BotBowl - which waddles around when disturbed by a loud sound or a bump to its display stand.
And I've got pieces on the list with inward overhanging rims - textured on the inside - and a ball or a large ball bearing inside to roll around - and generate sounds. A hollow form - with a Bot inside, causing the piece to move, and generating scratchings sounds as it treis to climb the inside walls of the piece.
How can I provide what I intend with these pieces, given the media available - and the files size limits of most sites where pieces can be shown?
Perhaps turnings are supposed to be static, and these other "things" are something different - outside the norms and organizations and structures for promoting turning.
But - imagine - a site, with YouTube features - specifically for dynamic and auditory pieces.
Just something to think about.
