ADVERTISE HERE - FREE TRIAL
O T but appropriate at this time of yr
paul waddle
>I discovered a new use for c a glue... My lawn mower pull string broke and I was having a difficult time rethreading it through the recoil starter. I'm sure a type of chinese draw gadget is made for this type of work,but I didn't have one. Here's where the c a glue came to my aid: I fired the end of the string to melt it into a reasonable point,took a small music wire and stuck in the middle of the string,applied ca glue to the end to stick the wire to the string,then proceeded without problems threading the string. Cut off the wire part,tied a knot so string wouldn't come out of the recoil starter, and back to mowing.. pw
Re: O T but appropriate at this time of yr
Re: Good idea----but
GalenV in Iowa
>You missed your chance to go buy a new one where you just have to turn a key or push a button! :>)
Galen
>I have one of those heavy-duty brush mowers, tractor-style tires, big dual-cylinder Kawasaki engine, hydrostatic transmission, will cut anything it will push over (usually 1" or more in diameter). It has electric start, with a cord-start backup.
A couple of years ago the starter battery gave up the ghost. Guess what - I found it starts easily with the cord, usually with one pull. I never did replace the battery.
