6" grinder?
Steven Kubien
>Hey there,
First of two questions today.... Any good reason not to use a 6" grinder vs the more conventional 8"? I knw it would produce more of a hollowgrind but is that a bad thing? If it is, why?
Thanks,
Steve
6" grinder?
Steven Kubien
>Hey there,
Thanks,
Steve
Re: 6" grinder?
>The difference in hollow grind is almost non existent. I used my last 8" stone until it was down to 5". It didn't hurt anything except using the oneway tool rest. At 5" the tool rest was riding quite high on the stone. If it was set up properly on a 6" grinder it would work just fine. I used a 6" grinder until about 4 years ago when I bought the 8
Re:There are few 6" low speed grinders....
Jamie D
>... on the market, and to my knowledge they all use 3/4" wide wheels. Narrow wheels are a safety consideration when sharpening turning tools that require rolling on the wheels to sharpen rounded edges, but I found little difference due to the hollow grind of a certain diameter wheel..
Re: 6" grinder?
keith zimmerman, Normal IL
>I use a 6" grinder with 3450rpm and my tools get nice and sharp...and they are quite usable.
I will admit though, that I have to be diligent about staying on the wheel when rolling my fingernail grind. I have slipped off more than once.
keithz
arkie
>The narrower stone requires more care. There are many variables that interact with speed but are usually overlooked. With high speed, it is easier to overheat a tool and damage the steel than lower speed.
First, the important aspect of speed is surface speed, not just rpm.
Second, it is the temperature the steel reaches that can cause damage. That's affected as much by pressure, speed of movement, and even friability of the wheel bond as by speed.
Third and last, the high speed steels most commonly used today, M2 and M4, are far less susceptible to damage by overheating (bluing) than the older carbon steels and some of the other HSS alloys.
Had I owned a 6" grinder with a good set of wheels, I'd have used it. Since I didn't, I bought the 8" slow speed grinder from Woodcraft. It's far from perfect, but it's the best grinder value I have found so far.
Re: 6" grinder?
Bruce McElhaney, Spring Lake, Michigan
>I have a 6" Baldor slow speed grinder and a Delta 8" slow speed grinder. the Baldor is much smoother and does a better job of grinding despite its smaller size.
Re: 6" grinder?
Gary Evans Tallassee, TN
>I also have a 6" Baldor which I acquired when I bought my lathe and other woodturning stuff from the original owner. It is very, very smooth.
Since I've never used an 8" I can't make a comparison, but I've never run into a problem using the smaller wheels.
Gary
Beep Beep!
Steve Kubien
>Thanks for the responses everyone. I didn't think a 6" would be a problem but I thought I had better ask first.
Sorry it has taken me so long to get back to you all. I've been breaking in a new computer and just trying to get up and running. Yup, I consider it a drive-by!
Steve
