need woodturning tips
>I'm running short of tips for American Woodturner. Look around your shop, I'm sure you have come up with a cool idea or gadget that makes life as a turner easier. Send them to me so I can submit them to the Journal for possible publication. If you send a photo send it as large as you can get through e-mail. I'll reduce it. I send 5x7"s at 300 DPI to the editor if you need to know a size.
Re: need woodturning tips
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>Here's a tip that I don't thing is used by many wood turners: It's difficult to turn those little nubs out from the inside bottom of hollow forms. Try reversing the rotation of the lathe and use a swan neck hollowing tool from the OTHER side of the nub;i.e. move the tool from right to left as the lathe turns in reverse.
Nifty one. Thanks!
Ellis Walentine, Host
bowlman
>Eliminating Sanding Scratches:
How many times have you thought your sanding was finished only to discover left over sanding scratches AFTER the finish is applied?
Tip 1: Clean your glasses!
Tip 2: Use one of those magnification head band things like Optivisor
Tip 3: Most effective is to make those problem areas really stand out. To do this, I keep a small squeeze bottle (empty ketchup bottle or something similar) nearby filled with mineral spirits. Slow the lathe to its slowest speed, squirt mineral spirits liberally over both the inside and outside. Stop the lathe. The mineral spirits make the problem areas stand out. Draw a circle around the problem areas. Let mineral spirits completely evaporate. With lathe off, sand the circled areas with the next coarsest grit. When you think its gone, reapply mineral spirits. If the problem area is still there, repeat. If not, go to next higher grit, sand and recheck.
Tip 4: If you have a lathe with reversing feature, sand in reverse every other grit. Say you start with 120 in forward. When you go to 150/180, sand in reverse. Back to forward for 240 grit. Reverse to 320, etc.
Steven Antonucci
Hands free finishing of hollowforms
Steve antonucci
>I think you've seen this one before form me, but I take a small wooden stick (dowel, popsicle stick, whatever) and tie a string around it on one end and a loop in the other. The loop hooks over a variety of objects in my shop, and the stick goes inside of the hollowform, giving me full access to spray the exterior without touching it.
steve
>Thanks I'll jot these down and get back to you. I need your mailing address along with the tip which is why I wanted them sent to my e-mail but I probably forgot to mention that. I'm on my way to Knoxville to do a demo tonight so I'll be out of touch until tomorrow. Have a good day.
>Eliot I now use the #4 hunter cutting from left to right with the lathe on forward rotation to get rid of nubs. The Hunter tip angle is 7 degrees so it lets you put the tool in almost straight to do this cut. I also use it to clean up the bottom of deep open bowls that don't allow me to rub the bevel with other tools.
charlie belden
>The Anal Retentive turner knows that there are other Anal Retentives who will HAVE TO put their finger in the hole in a hollow form and feel if the inside is as smooth as the outside - at least the area they can reach.
(side note: this may explain why some turners seemed to do hollow forms with impossibly small holes that no adult can get their finger in - thus eliminating the hardest part of turning - sanding and finishing - the inside. just a theory)
Anyway, one of the many things a turner should NOT DO is try to sand inside tight spaces using a finger to hold the paper against the wood. Those that have can often be identified by the Fat Finger symptom or have the nickname "Stubbee".
Solution:
"Curved jaws" hemostat to hold sandpaper for sanding up under the rim of a hollow form.
DO NOT put your fingers in the hemostat's finger holes - unless you would be comfortable with the nickname Lefty (if you're right handed) - or "Righty" (if you're left handed).
GalenV in Iowa
>Get a blue LED light and shine it into a hollow form or even a bowl and it seems to make the scratches, tool marks and open pores stand out.
For those that turn plastic pens the blue light sure makes some colors
more spectacular to dispaly.
Maybe a left over flash from my black light and velvet painting era.
Galen
Rob Wallace
Rob Wallace
>I don't know Charlie - you had me going there with the ANAL retentive and FINGER IN THE HOLE thing......
......had mental images of a proctologist, or the ever popular prostate exam.....
....Please don't do that to us!
Rob
jfox442
>Sanding sponges work exceptionally well with the hemostats. You can squish them to make the sanding part curve and match the inside of the hollow form or edge of a semi-enclosed bowl or vase.
James
Re: Hands free finishing of hollowforms
E. Tabachek
>Steve: I don't get it from your explanation. Could you fill in the details or post a picture? ET
Steven Antonucci
It's a simple device
Steve antonucci
>Take a piece of string and tie one end into a big loop so that you can hook it over a nail, a hook, or anything that might be overhead. On the other end, tie a small piece of stick in the middle (notch the stick so the knot doesn't move).
To use it, put the stick inside the hollowform and it will suspend from the string for full access to top and bottom and all sides. when it is dry, simply turn it upside down and shake until the stick and string fall out.
I have a picture somewhere, but I couldn't find it...
Steve
Re: Hands free finishing of hollowforms *LINK*
Bill McWhirter
>I tried a bunch of different ways to hold hollowforms for spraying. Most have failed at one time or another resulting in a damaged piece.
The best method that I have found is to use a clip originally designed to hold cabinet doors with the 35mm. holes for mounting hinges for painting. They are cheap, easy to place inside, hold securely, and are easy to remove. they are available from a couple of sources, one of which is noted below.
For larger vessels, I have a pair of old spring barbeque tong that I cut the ends off and bent that work the same way as the spring clips above.
Spring clips
