Popping The Curl
Popping The Curl
Popping The Curl
Jim Shaver - Oakville, Ont
>Hi,
I was reading the other day how some people try to pop the curl in maple. I have been using a process using analine dyes as per Jeff Jewitt's antique maple finish. It is detailed in FWW #135.
Here is my latest pepper mill using just such a process.
Photobucket
10" mill, amber and honey brown analine dyes, Waterlox top coat (12 coats), Beall buffed.
Be Well,
Jim
Re: Popping The Curl
David Walser
>Very nice. It appears you have the technique down!
I really like the pepper mill, by the way.
Dominic in Buck's County PA
>Nice job Jim! If I ever turn a pepper mill out of curly stock, I'll be picking your brain for the particulars on how to accomplish this.
Dominic
Good job Jim!
Jorge Castaneda~Downeast Maine
>the pepper mill is nice too
Jorge
Re: Question Jim? Since analine dyes.....
Jamie D
>... aren't believed to be light safe, how do you anticipate them lasting in a use such as this mill?
>Hi Jamie,
I was not aware of the concerns you bring up about them being sensitive to light. I have been using aniline dyes for some years and I have not noticed a light shift in the colours or over all finish. Perhaps I need to look at some of my sample pieces to see if there has been a change, but so far no changes yet. The clear coat I have been using on my mills has been very durable and maintained its finish. I made 12 mills for craft sales last fall and sold them all, they all received this finish and so far I have not heard back from the people who bought them. I imagine I will see some of those same people this fall at the same shows, I will be sure to ask and see how they are doing.
Be Well,
Jim
Mike Rubes, Apex, NC
>Hi Jamie,
I made a set of blocks for my son 11 years ago and colored them all with bright analine dyes. Very bright and vibrant greens and reds and oranges and yellows, etc. While they have only seen indoor use and the shellac top coat is a little scratched from normal little boy use, the colors seem as bright and vibrant as they were 11 years ago when new. They may fade over time eventually, but my one data point of 11 years seems to indicate that the fading is minimal to not noticable so far.
Good luck!
Mike
Bruce McElhaney, Spring Lake, Michigan
>Love the curl on your peppermill. But have to confess, it looks a bit phallic to me :-)
nailer
>To pop the curl in Maple I use a technique taught to me by a more senior member of our turning club several years ago.
Brew a cup of tea. Regular Salada or Tetley tea. Let it cool. Wipe it all over your maple turning. Allow to dry. Repeat to enhance the effect.
It really works great.
Once dry you can cover it with whatever finish/topcoat you choose. I usually use Tung Oil Finish.
I have also used Shiraz wine to darken the grain in plain old poplar. It really purples the surface. Again, more coats you apply the darker it gets. The interesting thing is when you topcoat it with oil. The surface turns kind of a rich brown with purple highlights. Really cool. Especially on a boring/plain wood like poplar.
---Nailer---
