REAL MILK PAINT
Info from Mylands
Info from Mylands
Info from Mylands
nick
>Here is part of an email I got from Jack Davis in Myland's sales department in response to my questions about their cellulose sanding sealer:
Doesn't need to be shaken or stirred, though won't matter if you do. Can be applied with either a rag or brush, most woodturners prefer the rag. Generally, two coats are preferred, though depending on the wood, could take three. Sand lightly between coats to remove any grain that might be raised. Myland's, for whatever their reason, just has not put the info on the can although we have suggested to them to do so many times. As a point of reference, however, we ship thousands of these every year and you are the first to ask.
I must be really dumb.
Re: Info from Mylands
Gary in Zirconia, NC
>I find it surprising that any company would recommend applying by rag rather than a paper towel.
allan
>Nick,
To clarify my earlier suggestion:
- Apply either the sanding sealer or friction polish to your work with the lathe off.
- For the first sealer coat, apply a generous amount of the liquid to your work, give the liquid a little time to soak into the wood, and then rub your work with a paper towel to remove the excess. Keep rubbing till the sealer is dry. Then run your lathe and buff your work with a clean paper towel.
- Try to get even coverage over your work. Some of my pieces have uneven spots (areas smoother than others), which I suspect is due to an uneven application.
Thank you for posting Jack's reply to your inquiry, and welcome to the Dumb Club . . . I'm a lifetime member.
