Grizzly G0694 vrs Powermatic 3520B
Gil Jones.....Georgia
>Does anyone own/use the Grizzly G0694, 20" x 43", 3-hp lathe?
If so, how do you like it.
Pros / Cons ??
Thanks,
Gil
Pros / Cons ??
Thanks,
Gil
Re: Grizzly G0694 vrs Powermatic 3520B
>I don't know anyone who has the Grizzly. I know lots of people who have the Powermatic. The Griz is 16" so you should be comparing it to the Jet 16/42. I like the outboard attachment. Throw away the cantelever tool rest. I've read many times about these things breaking and if it doesn't break will cause a lot of vibration. Personally I hate gap beds. They are useful for some things but I found myself constantly wanting to put the tool rest where the gap is. Maybe that's why they put the cantilever tool rest on. It is about the same weight as the powermatic. It looks interesting and their products have improved. They did change the spindle thread to a more universal size.
The Powermatic's biggest difference is the sliding headstock and it will take bed extensions. You can also put the short bed extension in a lower position which gives you a much larger swing.
Gil Jones
>Thanks, John. Pretty much what I figured, though this Grizzly is 20" over the bed, 24" over the gap, and 3hp. Still I like the PM.
Gil
Brad Vietje
>Gil,
I have never used that Grizzly model, but I do have the PM 3520-B. The Powermatic is a very good value for a full-sized lathe. Maybe the best choice depends on what you intend to turn with it. I was looking for spindles and bowls, but most important was hollow forms. For me the sliding headstock, allowing me to turn off the end of the bed made a big difference to my back and elbow health.
I agree 100% with John on the gap in the bed -- the rare convenience of a larger platter is simply not worth the constant hassle of putting up with the gap. Turning outboard is another option for this. The Grizzly looks like a well-made, robust lathe, but it would be better if you got to try one before buying. I would think about how often you intend to make a platter larger than 20", and how often you will make smaller things, or working the foot of a bowl, etc... The toolrest banjo puts the post further away from the headstock, which will make that gap an even bigger PITA for smaller items. I would prefer a design with the post offset the other way -- toward the headstock.
I looked pretty closely at options from Oneway, General, and a few other well-known brands, and couldn't beat the bang for the buck offered by Powermatic. I would have spent a *lot* more with Oneway.
As you read reviews of these models, keep in mind the PM 3520-B is a little different from the earlier 3520-A. Some of the early models had a fatal flaw: the metal disk that locks the headstock down was supplied in cast iron, which could (and sometimes did!) break under use. These were replaced with a steel disk, so the problem went away a number of years ago.
Have fun shopping,
Brad Vietje
Newbury, VT
Gil Jones....Georgia
>Thanks, Brad,
I asked the initial question for a friend, to see if anyone had used the Grizzly lathe, and if a comparison would be offered. I have a PM3520B, and feel it was the right choice for me.
Gil
