>Charlie ,here is a picture of how I place my skew to turn the winged vessels I make
Because I am turning cross grain ,I find it's the only way that I don't tear the wings off as the corners of the square come down onto the bevel
If a spindle gouge is used it picks up the end grain and it is all over rover
My recommendation is anyone wanting to try this (don't L.O.L) is to practice on a round piece of wood first.
I am only cutting with a 1/16 of the tip with the bevel rubbing .To practice mark the bevel of the skew on both sides with a felt tip leaving a 1/16 of an inch ,If a black mark appears on the work face you are cutting into the danger zone.
Please remember I have turned hundreds of winged vessels this way and are vary aware of what causes a mishap ,be careful
If you go to my web site www.timberly.co.nz you will see some work 600mm 2ft square that I have turned with this method ,cutting in until the handle is hitting the wings ,work the cut from side to side in a V
>Terry I've been using that cut for years for everything from goblet bottoms to tucking in tight areas between the bowl and an extended foot. I find it very useful to clean up the area just before the foot of a bowl when reverse turning the bowl. I also use it a lot when doing the initial cutting of the shoulder area on inside out turnings. I haven't tried it on a winged vessel yet so I guess I'll have to head out to the shop and go at it. Thanks for posting.
>John try coming around the whole bowl from foot to rim ,keep the handle well down ,cut with 1/16 of the toe rubbing the bevel .or place the skew at a 30 degree angle and use as you would a share cut on a a swept back winged bowl gouge same cut but without the other side of the flute
I have started doing a planing cut as well like Guilio showed me.many of my bowls know I start sanding with 240 grit .On hard wood bowls I use the skew and share cut the inside as well
The joke is I couldn't use the skew on spindle work if I tried
