finish to pop curly maple
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>I asked on the other message board what's a good way to get a dramatic effect on curly maple. What do my turning colleagues suggest?
Re: finish to pop curly maple
Steven Antonucci
See picture on Ellis's post below
Steve antonucci
>Oil is one way. Dye stains another. What color do you want the wood to be?
S
Dave Anderson (PacNW)
>I haqve found that Gloss Poly or lacquer are hard to beat for popping the grain. Rub down with wax and 4/0 steel wool and buff ror a better tactile feel
As Steve says...
GaryG in MD
>Watco Danish is one way, and RIT is another. Here is an example of both in one.
[Sorry for the terrible photo quality Jamie; I can do much better -- this was a rush job.] ...Gary
...and the photo...
GaryG in MD
JohnKyler
>I would use TransTint to enhance it and then an oil on the top will deepen it and make it pop. UNDERSTANDING WOOD FINISHING by BOB FLEXNER talks about this and it works. The book is a very good ref.
John
Jorge Castaneda~Downeast Maine
>Elliot,
Years ago I made a rock maple coffee table with a knock out curl, following a friend's advise, I used an alcohol dye in a very week solution, the alcohol goes in carrying the dye and evaporates and you can repeat until yo get the "pop" you want, I followed that with a 50 - 50 mixture of naphta and tung oil and then 2 weeks later a full strength tung oil, a month later I buffed and waxed. It came out very nice and the client was delighted.
I did try different colors in scraps, yellow, green, blue and red, my favorite was the green but the client chose the yellow.
Good luck
Jorge
My Process
Jim Shaver - Oakville, Ont
>I use a process that Jeff Jewitt published some time ago in FWW. It's a process of using two colours of aniline dye, both brown one darker than the other. It's an antique maple look that really shows up the curl figure with great enhancement that looks very natural.
First you apply the dark dye, let it set, then sand it off, it stays in the end grain of the curl. Then apply the light brown colour. I use a walnut brown and honey brown dye as my colours. Then I apply a tung oil then clear coat it.
Photobucket
Looks great!
Photobucket
Hope that helps,
Be Well,
Jim
Jerry Whitaker
>David Marks uses Tung Oil on his TV programs and the grain really pops.
Re: See picture on Ellis's post below------WebKitF
>The lady I'm doing it for says, simply, that she doesn't want it dark. And she is hoping for a dramatic effect.
------WebKitFormBoundarykpc4+VCA6QV0XTpb
Re: David Marks and Tung Oil
>David Marks doesn't use a straight Tung Oil finish but rather a wiping varnish with a Tung Oil base from General Finishes. He does not show the label on the finish because he doesn't get paid to endorse it. Careful observation of the back of the can and comparing it to the General Finish that I have used for years, I believe that I am correct. However I am not David Marks, I greatly admire him and it would be a dream to take his classes. David's television series has been a n inspiration as well as a learning experience and is greatly missed.
Re: finish to pop curly maple------WebKitFormBound
>I've noticed that no one has mentioned Waterlox . What about that?
------WebKitFormBoundaryPL22TsTH7adfu+ws
RIT?
Steven Kubien
>whaddat?
Steve
Re: RIT?
Carol - now back in Dubuque, IA
>fabric dye - try your grocery store
Rob Wallace
Re: RIT? *LINK*
Rob Wallace
>To a radio operator, RIT is "Receive Incremental Tuning"......
To most other folk, it's the brand name of a fabric dye with a long and noble history
See the web link below...
Rob Wallace
RIT Dye Website
Thanks
Steven Kubien
>There's an interesting set of responses to my question on the other message board. One in particular from Michael Dresdner remarks that the enhancing effect of oils is increased as the molecular weight of the oil is reduced. (Better penetration.) And soy based oils have the least molecular weight. So I'm kind of wondering if my Velvit oil ( which is soy based, no?) might be an excellent choice - at least as part of the schedule.
