Mylands sealer question
nick
>I've been experimenting with Mylands sanding sealer as a clear pore filler for open-grained wood. The manufacturer touts the product for this use. Unfortunately, I haven't been able to get good results. I've tried wiping it on with a rag, brushing it, applying two coats, etc. but the pores are nowhere near filled. There are no instructions and no website that I can find. I get much better results using Russ Fairfield's method with lacquer. Does anybody have any suggestions for getting this stuff to do what it's supposed to do?
Re: Mylands sealer question
Sean Troy
>What type of wood? You are shaking the bottle well? The project can't be much bigger than a pen or box.
paul waddle
>Tell me where to go to find Russ Fairfield's lacquer method. I have trouble filling pores in my boxes. I CAN fill them with woodfiller,but this makes the finish look cloudy. Thks,pw.
nick
>It's on this site but I don't know how to get there from here. Go to your search engine and search for Russ's corner. I'm not sure he says anything there about filling pores but if you follow his instructions for sealing with lacquer, you'll get decent results, if you include the last step, wiping with thinner.
nick
>I will try shaking the can, although it doesn't say anywhere to shake it. So far, I've tried it on walnut, red elm and bubinga, all small to medium sized pieces. Thanks for the advice.
two kinds
>There are two types of Myland's sanding sealer - lacquer-based (Cellulose) and shellac-based (Lacacote). I like the lacquer-based sealer better for most things but like straight shellac, the shellac-based sealer is better in some cases such as as a base under an incompatible finish.
I don't think either is intended to be used as a filler for larger pores, although several coats with sanding between should work. I use sander sealer often to toughen the fibers to combat tearout, especially on softer woods and punky woods.
I always shake before use.
Re: two kinds
nick
>Does lacacote darken the wood much?
Re: two kinds
Steven Kubien
>Not in my experience or in my opinion. Having said that, how much is a lot in your eyes? I don't mean to be sarcastic but it really is a relative thing. I notice very little difference.
HTH
Steve
allan
>Nick, like you I have just started using Myland's sealer, and my initial results left much to be desired. Fortunately, I've found an application method that produces good results.
Be sure your piece is sanded properly. No further sanding may be necessary after applying the sealer.
Cut a couple paper towel sheets into quarters, then fold each of those pieces into quarters. These will be used to apply the sealer to your work. Cover the sealer can's opening with a folded paper towel, invert the can and shake well - make sure an adequate amount of sealer soaks into the paper towel. Rapidly apply the sealer to your work, rubbing the sealer into the wood with some pressure. Continue this procedure until your piece has been completely covered with the sealer.
If your piece is on your lath, run it at around 1800 rpm and lightly buff the sealer with a clean piece of paper towel. Turn off your lath and check to see if the sealer developed those dreaded concentric rings. If they have, take the old sealer-soaked paper towel and rub it on your piece. The sealer residue on the paper towel will remove the circles. Next time, apply less sealer and rub it into your piece until it's dry before buffing it with the paper towel.
I apply three layers of sealer to my work. The sealer dries rapidly, so only a few minutes of dry time between applications is necessary.
After the third layer is applied and buffed (and rubbed, if necessary), you could stop here, or if you desire, apply another finish, like Mylands friction polish.
I've used this method on Christmas ornaments (3" diameter) made from a relatively porus wood (monkeypod, Samanea saman). In addition to the sealer, friction polish is applied (similar procedure as the sealer) and then buffed using the Beall system. The end result is smooth and glossy, but without the "built-up" look of other gloss finishes.
nick
>Thanks very much for the advice, Alan. I will try your method for sure. BTW, I wrote to Myland about their recommendations; I posted their answer is above. But their advice is similar to yours. Thanks again.
