Scorpion
Scorpion
Scorpion
Terry Scott
>Scorpion 2
Made from Black Maire, as I needed a piece of timber that would take the punishment of turning in the square with no waste blocks. This piece was made for the Royal Easter show for the small bowl category .The rules say the external measurements cannot exceed 250mm ,I made sure that across the diagonal that the measurement came into the range as last year I had a piece disqualified because I didn�t measure it properly.
As you can imagine turning up under the tail has its challenges. Also cutting down the outside of the rim to get a clean edge with the tail flying around has its moments .I had to bend a parting toll to get this crisp at the transition between bowl and wings.
The only way I have found to get down into the transition of the underside of the bowl and wings is with a spindle gouge that has been sharpened to resemble a dart (way swept back using the tool almost upside down
I still sand down to 600 grit before texturing if you don�t any chisel marks are magnified .I thought I would leave the contrast of the wood inside the bowl rather than gold leafing like the piece I entered last year.
The exterior body and wings were then air bushed with 7 different colours shaded so as you move around the piece it seems to move.
Because of the Maire (our densest timber) the piece is maybe a little on the heavy side as it will wheel stand backwards if weight is applied to the tail
I have started making these pieces as my winged vessels have started turning up around the place (copy these if you can )Grin
Comments and critiques welcomed
Re: Scorpion
Bill Blasic
Re: Scorpion
Bill Blasic
>Terry,
As I posted on another site this is mind boggling to me. An absolutely great turning. On another site yesterday someone had posted another piece of yours that looked a little like this but if memory serves me right it looked a little more ornate. I went to your site and it was Fly In For Tea that I'm speaking of and of course it is not the same but a beauty no less. Thanks to Alby and yourself I at least have begun to think about turning in a different plane.
Bill
Re: Scorpion
Re: Scorpion
Barry Elder
>Terry, as usual, this is awesome! You have a marvelously creative thought process.
Re: Scorpion
Re: Scorpion
Ed Conhaim
>Terry:
As a relatively new turner, this piece is simply mind-blowing. I cant even picture how such a project was turned at all.
Great job and what better inspiration?
Thank you for sharing these pics.
Ed
Re: Scorpion
Steven Antonucci
Just cut the wing off and glue it upside down? :-)
Steve antonucci
>And then cover the joint in texture and paint, right? ;-)
As usual, the mechanical process is baffling and the resulting work is breathtaking!
S
Re: Scorpion
Keith Tompkins
Re: Just cut the wing off and glue it upside down?
Keith Tompkins
>Steve. I have a pretty good idea how he did it, but I don't want to spill the beans. My guess is that nothing had to be cut, flipped, and reglued, but a total of four wings did get removed. Nice job, Terry.
Re: Scorpion
You just spill the beans!
Jorge Castaneda~Downeast Maine
>Thanks Keith,
Very ingenious.
Jorge
Re: Scorpion
Jason Clark
>If I'm picturing it how you're picturing it (and I'm pretty sure I am) then you're right, a total of 4 wings were removed.
I haven't spent much time in the shop lately due to work and family commitments, this might be a fun little project for the next evening I actually spend in my shop.
Jason
Re: Scorpion
Re: Just to add to the boggle your mind....
Jamie D
>...factor, Terry turns these wings with a SKEW!!!! AWESOME!!
Re: Scorpion
Don Pencil
Re: Scorpion
Don Pencil
>I believe I'm in love with this one.
Re: Scorpion
charlile belden
>I watched Jimmy Clewes turn a "chinese hat" piece - with a fingernail ground bowl gouge - and that was pretty impressive. I used skews - a lot. I can't imagine turning The Scorpion - with a skew!?
