O T slighty- router speed control
paul waddle
>I need to slow down my trim router that I use to cut threads in my ring boxes. I've tried the Harbor Freight control,but it saps the power. Can someone advise another speed controller? Do I need to just get a bigger router with a built in speed control? Thks,have a great day,pw.
Re: O T slighty- router speed control
>Paul I am wondering why you need to slow it down. Are you getting burning? Try to keep it moving at all times and it usually won't burn except in woods like Cherry which has a tendency to burn if you breath on it wrong. I'm using a standard Porter cable router and it runs at 23000 rpm. I'm using the 3/4" diameter cutter from Bestwoodtools. Occasionally I get some slight burn but it's nothing I would worry about. I do take lighter cuts in the woods that tend to burn. I might make 3 passes instead of one full depth pass.
To answer your other question I bought my router speed control from either Grizzly or HF, I don't remember. It loses power at really slow speeds but seems to do fine at 50 percent or above. I use it in my router table and often use it at reduced speed especially with larger bits which need more power anyway. I'm sure there is a difference in quality of all the units but I didn't buy good quality to begin with.
paul waddle
>Thks John,my router turns at 23K+, and I do get some burning. Other than looks,the threads seem strong enough.Bonnie Klein cuts at speed of 3K-5K, and a dvd shows her cutting threads with a Foredom tool(but these turn at least 15K)? Maybe some tools have a variable speed control. I will look into the Grizzly model,but if I recall somewhere,there is a type that attenuates the voltage and one doesn't lose the power as with a pure resistor type..or is this just with DC??
Slightly ot,I have found with soft woods,one can use the same wood,but cut out and put a pc of the same wood in with the grain running crosswise and the threads will cut cleanly. If color match is not a problem,use dogwood with the grain glued in-it works great. pw
>Most people use the lathe headstock to turn threads. They only run about 3000 max. I wanted to try a faster speed to see if it cut cleaner on soft woods. I can't really tell the difference but it is nice having a separate threading lathe to take to demo's. Hopefully when I get my little Jet mini working I can go back to using the lathe to make the boxes and thread them.
paul waddle
>Actually John,one of the commercial threaders use the head stock to turn the box/top and the tool post or thread crosswise adjuster(for lack of better nomenclature) with a motor driven cutter. It takes some plastic gearing(ala Beal type), butI think it overcomes,at least for me,the induced error of moving the chuck to another shaft. Try as I will,its very difficut to turn a shaft that will be concentric with the lathe shaft. Possibly the Baxter is machined on cnc equipt,that does better than manual lathe operation. Whats this got to do with speed? heck if know. ha ha. pw
>It's probably our lathe headstock that is off. When I turn a box on the Powermatic or my Nova and then use the Baxter threader it's off just a little. I thought it was the threader so went to visit Vic and he measured it while I was watching and it was accurate to less than .0003". that's 3 ten thousandths. He said it has been quite common to have even expensive wood lathes with headstock spindles that are off just barely and it's enough to cause this inaccuracy.
paul waddle
>Wow,I would be happy with 10 times that much-.003. I measured my jet mini and its off about .0015-plenty good for me. Its when I move the chuck to a different spindle that I have some run out-about .005-it would really be nice to not remove the chuck from the lathe. A master tool maker who worked out at Naval Ordance, and rebuilt part of the Iowa's gun turrent is supposed to come over and straighten me out... ha ha. I can't really say I have a problem,my boxes screw together fine,its just knowing something is off just a bit and I don't know what is causing it... Maybe we can trade boxes-nothing special. Now where did that speed control discussion go...pw
