SketchUp for modeling Inside-Out turnings
Lloyd Johnson
>I've found SketchUp to be quite useful for modeling Inside-Out turnings. It lets you experiment with profiles to see what the design and the resulting wall thicknesses will be. The process mimics what you would actually do on the lathe so the finished product will be identical to the model.
I made this model in a few steps - first the ornament which takes about five minutes and then the finials which is another five minutes. Then I made the hanger which was actually more difficult than the ornament. Finally, I added the plant and mirror from a 3D library and the table from another model I created. I then rendered the file using a ray-tracing program called IRender.
There is a fairly steep learning curve to SketchUp, but if you're willing to invest the time, you'll be amazed at what it can do to help woodturners.
Lloyd Johnson
