Wood stabilizer for pen blanks
GalenV in Iowa
>I am trying to use some pen blanks that are spaulted and faily soft.
A few I have turned I put lacquer sanding sealer on them before they get to shape and let it soak in good and then turn again. Even a second coat as it nears final shape.
When trimming ends I had put on a coat of CA to help prevent tearing.
Elmers makes a rotten wood stabilizer but nothing on the MSDS sheet say what it is. Wonder if it would work?
Is there something I can soak the rough blank in advance of cutting and turning to harden the wood? Are corn cobs stabilized under a pressure system?
I hate to give up on some of the blanks as they do yield some nice pens but my current method is slow and does not always work so I lose the brass tubes.
Thanks
Galen
Re: Wood stabilizer for pen blanks
Carl Barton
>Galen,
I have some really nice spalted maple someone gave me and I have made a number of pens from this material. Of course a number of them split, chipped etc etc etc on me when I turned them. The only thing that worked for me was giving them a good soaking with CA after I drilled the hole for the brass. Of course I had to re-drill the hole again but that seemed to do the trick. I also soaked the outside of the blank as well. I stopped turing often to look for more cracks,chips etc as I turned the blank. I still had a few that did not turn out, but I had more pens than before I did all the soaking with the CA.
Carl
Al Neighbors
>I have a qt coffee can that I use for stabilizing spalted, punky, pen blanks in... some of them were so bad you could turn them with a finger nail.
I fill the can about 2/3 full with 60/40 Thinner/Lacquer mixture. When I put the blanks in the mix, I lower them in gently, not allowing the liquid to get on the upper end. That allows the liquid to enter the lower end of the blank, as the air escapes from the upper end. You can have as much as an inch and a half of the blank sticking out of the liquid, and it will still wick up all the way through. The lid on the can keeps them from floating.
I leave the blanks in the mix over night, and then let them dry for a couple of days. I haven't lost any to chipping or flaking with this technique. It works for me.
Jeff Brockett
>I give any spalted or soft pen blanks a soaking in medium CA glue. Sometimes a second coat helps out. If there are voids in the blank I will mix up a slurry of fine wood dust, cinnamon spice (my wife wonders where it all goes) or crushed stone and work it into the void.
Thanks Carl, Jeff & Al
GalenV in Iowa
>On a couple that are still not turned I did use a cotton swab and put Lacquer sanding sealer in the drilled pen blank and not CA but should work similar to CA. I used medium CA on most so it may help bind the brass tube to the porous inside. I guess if I was going to soak a blank I would have submerged them full but see how letting it wick and maybe let air out would help. Surface tension may never let it soak through my way.
Part of going back to pens was to use a rectagular skew I purchased. I hated my oval skew and think I can do better with the rectagular. Even was easier to sharpen.
I stoped on boxes for now but sure found my Thompson detail gouge a great tool for hollowing and some of my boxes could be deeper and no problem with the stiffer detail gouge.
I am enjoying learning and the help I get on Wood Central.
Thanks again
Galen
