OT: Steel Question
TomCollins
>A lot of you seem to know a lot about the different grades of steel so I thought I would ask here. My mower deck has a 1/2in rod that runs the width of the deckh rollers on it that support the back of the mower. The original rod took a lot of abuse (12 years)but I finally bent it. I replaced it with a rod from Lowes last spring and fought with it all season getting it bent back into place after each mowing. I need to replace the rod again this year. I am wondering what grade rod should I look for that will stand up to the abuse. I need to be able to drill a couple small holes in it but could use a spot weld if necessary.
TIA,
TomCollins
