I Need Opinions....
I Need Opinions....
I Need Opinions....
Wally Dickerman in Arizona
>Anybody use the Merlin miniature power carver? I'm thinking of getting one and I'd appreciate your opinions, good or bad.
Wally
Re: I Need Opinions....
Don Evans
>I don't have one of those Wally but just thought I would give you this link for video that goes through the tool and attachments for it.
http://www.youtube.com/watch?v=BO43tMZnBLU
Don
arkie
>I've used larger versions of the same in the past. The chainsaw disc is better for green wood than dry. The structured carbide grain discs work well, but raise horrendous amounts of dust. Plus you need a firm and steady grip to use either safely. If you can handle a chainsaw, you're probably okay in that department.
Don Evans
>I learned a couple of things while looking at these just now.
First it comes in fixed or variable speed. Also there are different chains some more agressive than others, that may apply to the 4 1/2" for an angle grinder however.
The price for the kit from the maker: www.katools.com seemed to be the same for fixed and variable $235.00 for the kit, while Woodcraft had a $204.00 price on it they don't mention variable model and one shown is the fixed one. I can tell cause the variable model has a round knob in front of the on/off switch.
Don
Dale Cook
>I had one Wally, it died the second time I used it,I've since switched to an arbortech which is a little heavier but much more power.
>Wally when I was looking I asked a lot of questions. Apparently it is only for light duty. Several people posted saying they had problems with it.
I bought the Arbortec. The only problem I have with it is it cuts so easily you have to watch the cut because you can't "feel" it. It is also more of a 2 handed tool but this gives you a lot of control. It can be one handed if you have larger hands but I've been using the 4" chainsaw cutter for so long the smaller arbortec feels good using it with 2 hands.
bill Crommett
>It was my opinion that the Merlin was underpowered.
Eduardo sarmiento-hall
>Hi check this place I have been looking at all places for power carving and this one is good and the prices are well in swing
www.woodcarverssupply.com,they have a tool like a screw driver in there but is a rotary carver ,i have a chinese one and it works fine ,also they have every bit,disc ,and others that will keep you happy,I got my chuck and now I will save to buy at least,the whole set of carving wheels,men they work I have used like hell and they last ,my 2cents
Arbortech
Rick_Allen
>I lusted after that tool for a couple of years. As I looked into it the word was that the Proxton was the weak point. Some said that it was a light duty tool. Most said the Proxton didn't last very long.
I redirected my lust to the Arbortech and bought one a few months ago. The Arbortech is a beast and is likely overkill for the cutting edges which attach to the device. But the Arbortech cuts any way you like and the control is much much better than you would expect and the cutting edges cut through wood with very little effort.
Carole Valentine
>I have the Arbortech mini attached to a Makita grinder. Have not used it much yet, but when I played with it right after I got it, it seems to work great. I need to get the 2 tooth carbide blades.
Steve Russell
>Hello Wally,
I demonstrated for several years with the both Proxxon Mini-Grinder and the Arbortech Mini-Grinder (as well as the larger Industrial and Pro Carver model, plus one or two that were never offered for sale here) and I use them both in my studio for various tasks, with numerous cutting, grinding and polishing disks.
If you send me a email and tell me what you're thinking about using them for, I will be happy to give you a through run down on each model. I would post it here, but I get hammered every time I post anything that is more than a few sentences long.
It seems there are some who prefer only brief responses, even when they may not be sufficient to answer the question. Take care and best wishes to you and yours!
Better Woodturning and Finishing Through Chemistry...
Steve Russell
Eurowood Werks Studio
The Woodlands, Texas
Dick Hines
Dick Hines
>Don't have the Merlin but have the Lancelot carving disc. It will remove a lot of wood. Sort of like a beaver that has been smoking pot and has the munchies.
Thanks For Your Replies....
