Have a question? Ask Woody!
Totally OT: how to turn heat into electricity?
ILYA ZAVORIN
>This is a "green" question: do you know of any household devices that could be used to turn waste heat into electricity? For instance, my attic gets very hot in the summer. The question is whether it's possible to turn this heat -- not the solar power directly -- into something usable like electricity. There are certainly other examples of waste heat around the house. Thanks.
Re: Totally OT: how to turn heat into electricity?
Ralph
>Not cost effectively
Texian
>If it was easy and relatively inexpensive we would all have one in our attics around here. Damn good question though.
John Veerkamp,Western Mo
>How about using it instead of electricity to heat water. If you put a coil in the attic and ran your water thru the coil before going into the hot water tank you could use at least some of the waste heat. put cutoffs and drains in the line so that in the winter you can bypass this leg and not worry about freezing.
Just a quick thought.
John
Dick Coers
>I saw a rig on TV that used a parabolic mirror, focused on a Sterling cycle engine, that turned a small generator. All that was in a single unit. I haven't researched Sterling cycle engines, but it was a pretty small unit. Maybe something to research.
Sorry, Stirling engine *LINK*
Dick Coers
>Link also shows the rig I was talking about.
wiki link
GalenV in Iowa
>There is probably supporting data that says it is cheaper or more efficient to vent the attic heat my natural ventilation and reduce you cooling cost for the house in the summer.
Same goes for using microwave oven over conventional to reduce heat in the home.
The preheating of your hot water heater supply sounds like a good idea but there may not be any cost savings overall for the cost to build and have a large enough heat transfer system.
If you think up an idea that works let me in on it.
Like trying to recover the heat generated by turning wood. Guess it can heat colds hands in the winter.
Galen
Bill Howatt
>Look up Peltier device. This is the solid-state device sometimes used in portable electric coolers. Certainly may not be cost effective.
Bill
Brad Vietje
I guess I should jump in here...
Brad Vietje
>...since I'm a solar system designer/installer.
Ilya,
The heat in your attic wouldn't be concentrated enough to do you much good. The gizmo(s) you'd want to look into are Stirling engines, as well as the newer Stirling/Rankin hybrid engines. There's a fellow names Jeff Sterling ("e", not "i") who's been prototyping a Rankin/Stirling engine in Florida.
Responses to other comments: You could pre-heat your domestic hot water somewhat, but again, that would be a pretty diffuse heat, instead of a more concentrated form, and likely would not be worth the plumbing cost/effort. Solar attic fans are a great way to reduce the heat buildup in attics, and make their own power to run the fan. As an aside -- if you are gaining too much heat in summer, you are also almost certainly losing heat during the winter. I'd look into better insulation and better air sealing.
If you are at all concerned about the rising cost of heating domestic water (and most people should be), by all means look into a solar domestic hot water system. Unless your fuel rates are VERY low, or your electricity is all but free, this is a cost-effective option, and in most states, a very sound investment, as well. The designs and equipment will depend on where you live, and how cold it gets. Systems in Florida are quite different (and cost less) than those here in Vermont. The actual calculation of cost, rebates and such is found at the DSIRE web site, linked below. Each state has different rebate programs (some have none), but in most cases, you can claim a 30% income tax credit for SDHW systems everywhere in the United States with no limit.
Clear skies,
Brad Vietje
Newbury, VT
Brad Vietje
Where'd the link go???
Brad Vietje
Brad Vietje
Where'd the link go???  *LINK*
Brad Vietje
Solar Rebate Programs, by State
Brad Vietje
Additional Tax Credits  *LINK*
Brad Vietje
Additional Energy Star Tax Credits
