killing bugs in a vessel
>ONe of my good friends called me while I was on the road and asked how to kill bugs in a finished vessel. I know I've read some suggestions here but couldn't find them. Anyone have a solution?
Re: killing bugs in a vessel
Re:2 suggestions for situations .........
Jamie D
>...like this. 1. is to nuke it in a microwave to cook the critters, and 2.is to place it in a plastic bag with some moth balls for several weeks. Both of these methods have worked well for me in the past, but I don't nuke if the piece has been finished for fear of damaging the finish.
>Jamie I'll tell him about the moth balls. It's too big to Nuke.
bill Crommett
>Another fix is to put the piece in a black plastic garbage bag and let it sit out in the hot sun for a couple of days. But be aware of the effect of the hot sun and moisture on the workpiece.
Dick Coers
>If you try heat, according to the kiln guys, you have to have the stock above 130 degrees, all the way through. I've seen suggestions about contacting a local museum. They know how to handle old wood that can have powder post beetles. I think they use a gas to kill everything, but I sure don't have any experience with that procedure. Well I do have a problem with gas occasionaly, but that's something entirely different!
Walter Ahlgrim
>Putting the work in a plastic bag with a glass bowl half filled with 8 ounces of denatured alcohol for 3 days. This will not leave the work smelling bad.
Walta
Frank C. Joseph
>put the log in a trash bag and spray it , spray it heavy close the bag tight and set it aside for a few days....
Dave Peebles Lyons, Ohio!
>Hi John,
I am wondering how thick the walls are on this vessel? The answer may be to turn it thinner. :) I have sliced many a bug... and some ants in my time on thin vessels. They don't do too well without their heads. :) If all else fails, put it in a room and play some ABBA for a couple of minutes... that would do it for me..
Dave
spray with what ? inquiring minds want to know
mamma mia, mamma mia :)
Re: mamma mia, mamma mia :)
don lewonczyk
>John go to your CO-OP farm store and pick up a can of fogger that is used to fumigate tobbacco beds. I don't remember the name of the stuff, it's been 20 years since I grew tobbacco. Read directions but what you do is put the piece in a lage heavy gauge plastic bag put the fogger in with it, seal the bag and push the can down into its holder which puctures the can and lets out the gas. Leave it the sealed bag for a day or so and handle with rubber gloves when you take it out and air out very good. What ever finish you have use a cleaner solvent that won't hurt it to wipe it down. Good Luck, DonL
Re: spray with what ? inquiring minds want to know
Barry Turner
>Machine gun fire?
Uhhh........Maybe Not!
Barry Turner
>The stuff you are speaking of is methyl bromide gas. We used the stuff years ago for fumigating tobacco plant beds. They also use it in the south when they tent houses and fumigate for some kind of beetle. This stuff is DEADLY. I doubt you can even buy it without some sort of pesticide certification. I would not recommend the use of this stuff indoors by anyone, certainly not inexperienced hobbyists. People have been killed with this stuff. Please stick with microwaving, freezing and other non-toxic methods.
Re: Uhhh........Maybe Not!
Barbara Gill, Remlik VA
>Barry, you are right about that. We were still able to get Methyl Bromide which we used on old material (pre-Revolutionary War) to get rid of powder post beetles. We took extraordinary measures to maintain safety. I am not sure it is still available.
Spraying a log with a bug spray from the store and putting it in a bag will do nothing for powder post beetles. It might kill something hanging onto the bark.
John
>If the vessel has a serious bug problem, I would think the best way to handle it is to contact an exterminating company and see if they could gas it. I would think soaking in alcohol, heating, or freezing might ruin a finished vessel.
>John, I can think of about four or five ways, some already mentioned.
The Methyl Bromide would work but is deadly. Not only to the bugs but to you. A similar chemical or at least one used for similar purposes is Viacane (sp?). We used them as described on the farm when I was kid to sterilize plant beds.
You could freeze it. A few days in the freezer should do it.
You could heat it to above about 130 Degrees. (Kiln, black plastic bag Solar heated green house.)
All of the above may or may not damage the finish.
Another way to do it would be to bag it in heavy plastic and put a chunk of dry ice in the bag with it. (Available at Kroger Grocery stores and purveyors of dry ice.) The carbon dioxide displaces the air and the bugs suffocate. This is less likely to damage the finish if you keep the dry ice off the finish directly.
Wonder if you could bag it in a veneer press bag and draw a vacuum on it? Suck the life out of the little devils.
A safer chemical is BORA CARE. Based on a borate, it is relatively harmless to humans. The borate is suspended in glycol which helps it penetrate into the wood. If the inside of the vessel is not finished, you might be able to soak the inside with Bora Care and it would penetrate the walls and probably kill the bugs. Don't know what the affect would be on the finish or appearance.
Naphta or CA
Jorge Castaneda~Downeast Maine
>John I had some luck injecting CA glue or naphtha in the little holes, in every single one, then putting the piece in a black plastic bag for a few days.
The CA sometime is visible, not a big deal if you still have to turn the piece to final shape.
Dick Coers
>If I remember correctly, if you see powder post beetles and holes, you are only looking at one generation. This generation has hatched and bored their way out. I can't remember if, or when, that group lays new eggs. That means more holes and dust.
Dick Hines
Dick Hines
>John, years ago when I built model ships I had one that had bugs in the hull. I would leave it for the night and the next morning there would be these little piles of bug dust. I tried everythig to get rid of them. Finaly I put the modle in our frezzer. I turned it down as low as it would go and left it for a week or so. The ship looked like it had been on a trip to the Artic when I took it out butI had no more trouble with the bugs.
Re:Attempting to kill bugs by freezing......
Jamie D
>... is seldom effective, because most of them have evolved by surviving thru winter freezes well below 0 degrees F.
Thanks everyone. I've passed these on to my friend
