Vacuum adapter
Vacuum adapter
Vacuum adapter
mfoster
>I have been using my own version of a vacuum adapter for years which allows me to leave it installed, yet still use a knock out bar to remove MT drives. This adapter failed, (bearing seals disintegrated) about 2 mo ago.
I finally got a decent vacuum with a new adapter. I went through several different replicas with poor suction and was getting rather frustrated. I thought the problem was vacuum leaking through the bearings. After finally resorting to this version, and still getting only 8 in of hg I realized my problem was not the bearings. I thought the closed cell foam that I had between the wood wheel and the metal handwheel was fine, but in fact this was where my leak was. After my latest construction was only pulling 8 in of hg, I placed a small bead of silicone sealant between the handwheel and the wood wheel adapter, and presto, 22 in of hg (all my pump will pull).
So the pics show my version. I started with a 1/2" brass nipple which will allow a 3/8" bar through the lumen as a knockout bar. I took the nipple to the local auto parts store and found some bearings that just barely did not fit over the nipple. I bought a 1/2" barbed brass nipple and a 1/2" brass nut for a compression fitting for either end of the nipple. the barbed fitting allows a 3/8 bar through and accepts a 1/2 reinforced tubing from the pump. The nipple was chucked up and turned (using a scraper) to just accept the bearing. I cut off the small end of the compression fitting to act as a keeper nut on the inside. I used nylon washer that my local hardware store had which fit over the nipple to separate the bearings and allow for a layer of vacuum grease. I relieve the center of each washer (on both sides) on the lathe so that the inner bearing surface of each bearing was free to turn. I found the hardened washer that fit on the inside to act as a retainer for the sub-assembly and secured it with 3 wood screws. I went to these lengths to allow me to replace defective parts, rather than remake the whole thing, should something fail.
I used vacuum grease between the washers and bearings and in the gap between the plywood and the barbed fitting. This may have been overkill, but I now have a seal that gives me as much suction at the headstock as my pump will provide, and it takes seconds to disconnect the suction and allow use of a knock out bar. I think the pictures will help explain any ambiguities of my description.
mike
Re: Vacuum adapter
Re: Vacuum adapter
mfoster
Re: Vacuum adapter
Re: Vacuum adapter
mfoster
Re: Vacuum adapter
Re: Vacuum adapter
mfoster------WebKitFormBoundary6h+hF1gNvuvabq+x
Re: Vacuum adapter
Re: Vacuum adapter
Re: Vacuum adapter
Re: Vacuum adapter
