Re: In Pursuit Of A Wild Hare (Scurrying Bowl)
charlie belden
>Steve A wrote
To make your vessel lighter, you need to get below 1/4" wall thickness. Wht not rechuck it and have at it with some sand paper? with a
1/4" wall, you waren't likely to sand through it, and you could probably drop an ounce or two pretty easily?
This thing has been chucked and rechucked and reverse chucked probably thirty times by now. That always seems to introduce some wobble. Add the fact that the wood is still wet - and drying too fast may cause it to crack - and keeping it round is almost impossible.
So, while the wall thickness may be a quarter inch in one area, the opposite wall may be thinner. Repeatedly checking wall thickness can be misleading - if you measure at the thick spot rather than the thin spot.
The other problem with this Thick Here, Thin On The Other Side thing is how the tool I'm using works. All Captured Systems's cutters work as scrapers, not actual cutters (shearing). So beginning a "scrape" is tricky in an asymetric wall - air, air, air - WOOD! - air - WOOD! - air. A catch at this point would be disasterous - as I discovered with another hollow form I was turning between turning sessions on the BotPot. Things were going well - until that - "You're about to turn through the wall!" occurance. Even at 500 rpms, there's no time to react between hearing the symptom of the impending problem - and the problem happening.
Higher rpms would reduce this air-wood-air-wood thing - but remember - this piece is green - wood ain't as strong green as it is dry - AND - it's getting kind of delicate.
And Steve A suggested making Battle Bots - The Micro Bit Event
The idea of one of these things - with a spike that would shoot out of it could be interesting - once.
and Dave wrote:
is there enough space within your hollow form's foot for the legs of this critter to move and articulate? Can't tell from the photo.
Keep exercising that curious brain of yours!!!
Yes, the photo is deceiving - the Bot in the foreground appears larger than it actually is, relative to the Pot. The pictures are spur of the moment snap shots just to have some images to put up.
I was helping a neighborhood 8th grader with her science project - that was due two days earlier - and was going to take my sons and their wife/girl friend out to dinner that night - so time was kind of tight.
(The science project was finding out the relationship between the temperature of water and how much sugar could be dissolved in it at different temperatures. Weigh the sugar before adding to the water, keep adding 'til it stops dissolving, record the water temp, weigh the remaining sugar to determine how much was dissolved - then graph the results of six samples. From the graph an equation of the relationship might be worked out.)
Eventually, if this BotPot makes it to completion - and works - I'll break out the light box, seamless background and lights and shoot better photos for the web page on this thing.
Yes, there's room in the "foot" for the Bot and its leg movement. I turned that space first and left myself a bit under 1/8th inch of "slop".
As for exercising a curious brain - I'm starting to notice that my originally black, now a dark beige/light brown sawdust covered hat is beginning to feel a little tight. Could be brain growth - or I'm becoming a Fat Head ; ).
Randy asked
... Is there enough gap for sound to still get in to the bot at a level to cause it's Action?
The bottom of the BotPot is a bit over 1/16th inch off the surface it's sitting on (table top) and the walls of the base aren/t very thick - so sound - or vibration - does reach the little sensor on the Bot.
The real issue with this thing is weight. The Bot operates off two 3V,smaller than a dime, batteries and the little motor doesn't have that much torque.
What I SHOULD have done is stack coins on the Bot to see how much it can deal with - weigh the coins- THEN decide to turn a piece or not.
I've since done just that - and it the Bot can't handle much over 63 grams - or 2.22 ounces.
I can remove some weight from the BOT and pick up a few more grams (28.35 grams = 1.00001 ounces for the conversion phreaks) but it looks like the carrying capacity is about 2 1/4 ounces.
This just might be a Mission Impossible quest.
Brad:
I'm out in the San Francisco Bay Area - in Silly Cone Valley (others call it Silicon Valley) so I'm afraid I won't be attending the NE Symposium. Perhaps you'll make it to the Left Coast someday.
As for getting the walls thinner - even with a captured hollowing system - with laser - this piece was turned green so even though I've been turning it progressively - turn some - store in fresh shavings - turn some more - and because of the chucking, rechucking, reverse chucking - it's stayed close to round, but not close enough to round to try turning to 1/8th inch all thickness.
I'm probably going to have to Swiss Cheese this piece to get the weight down to a bit over 2 ounces - and do it so you can't see that the inside of the hollow form has a bump in it hiding the Bot.
OR - though I'd hate to do it, the HF is pretty nice , and feels quite sensuous, I could cut off the top, add the micro-balloons for filler and to hide the "bump" and be done with it.
OR - I could start with lighter, dry wood - like walnut or poplar or magnolia, and turn a bowl for the Bot and go back to my original Scurrying Bowl idea.
However this works out, it's been interesting and fun - which is what I'm always after.
Still looking for ways to add movement to an otherwise static piece - created by a very dynamic process - turning.
EDITORIAL:
My intent here is not to show off how creative I am - but rather to give others who don't THINK they're very creative some insight into how things like this develop. It ain't rocket science or anything - and it's just a matter of unlearning how to NOT be creative. Of course, as I've said before - a little caffiene, some sleep deprivation and a dab of hypoglycemia helps. Oh - and kids imaginations help too - a LOT. They haven't accepted all the You Can't Do THAT rules we adults accumulate so they're full of ideas and seem to really dig getting an ADULT to listen and be interested. They LOVE attention - and if you provide some - the return on the investment beats the hell out of banks and the stock market.
