Tax Software
Tax Software
Tax Software
Doug Thompson near Cleveland
>Now that the tax season is over it's time to prep for next year. I download the information into Excell then cut and paste the numbers for days... the bookwork is the toughest part of all this. Is there a program that will make life easier... I did try Quickbooks but it doesn't work well for a manufacture, a retail business would be fine.
Re: Tax Software
Re: Tax Software
>What's wrong with the "usual" software? TaxCut Premium has all of the business "forms" included. I'm sure TurboTax does also.
Re: Tax Software
Re: Tax Software
Doug Thompson naer Cleveland
>I never tried them but to keep buying software to try out gets expensive, I hope someone found something good to save a few bucks. My accountant still uses paper and pencil so she doesn't care but every sale/expence has to be compiled to get the bottom line.
Re: Tax Software
Borrow a copy of Quicken
Adrien
>You can set up categories and then print a sorted listing. CPA could take it from there. I say borrow a copy so you could check it out.
Re: Tax Software
Re: Tax Software
Carol - now back in Dubuque, IA
>Tax software for a manufacturing operation always eluded me too, Doug. I had my accountant set up excel sheets for me. Each month I opened a new one copy and I was good to go. I just took the disk to her - before email!
Maybe your accountant will do a blank copy or copies for you and you can create excel sheets, print them off for her... Well, you get the drill. Cheaper than buying software that has to be modified and learned.
Re: Tax Software
Re: I have been using Quicken( I should.....
Jamie D
>.....qualify that by saying that my wife and CPA have been using it). Now that she's gone I have actually been able to continue using it myself for both business and personal records without much difficulty, and this is the older 2005 version.
Re: Tax Software
Jesper, Denmark
Re: Tax Software
Jesper, Denmark
>I had good experiences with QuickBooks Pro, but it was 10 years ago and not in a manufacturing company.
I suggest you talk to your accountant and see what they would suggest.
Miocrosoft has an accounting software, where the simple version is free to download here: http://www.ideawins.com/OAProDownloads1.aspx
It is only for US and UK situations, so I have not tried it.
Re: Tax Software
Re: Tax Software
>Thanks I'll need to try some of the programs to see if they work. In this day and age of computers there has to be a way to drop the information downloaded from a account right into a program. When the information is downloaded into Excell there is so much that is not needed one hour is lost deleting that stuff. The accountant only needs the final figure, I need a way to get that to her without going nutty.
Re: Tax Software
Jesper, Denmark
Re: Tax Software
Jesper, Denmark
>Don't delete. Hide the Excel columns you don't need and make additional columns in the spreadsheet that copies the data the accountant needs.
I can download the running statements from my bank, including document numbers into Excel. I can also upload the Excel into the Accounting software, and as long as I re-name and re-arrange the columns to the headings needed in the software, it is very easy.
It is simplified if you only use one account for all the business transactions, so all income and expenditure always is from and to the current account.
Re: Tax Software
Re: Tax Software
Don Evans
>Doug:
Based on what you have said, I agree with others that Quicken is good way to go for you.
I'm talking about the regular Quicken. You can set up "Categories" and give some thought to them and what you will use them for. Example would be a category for "biz expense" and everything you spend for that plug that into the Category column when filling out. It works just like a check book register. I keep track of checkbook (let it do the math and I just copy figure into paper ckbook register, so no math errors there. Also track credit card spending etc.
Then when tax time comes you can print out "reports" based on those "categories", like biz exp, biz income, this keeps it separate from your personal stuff in the report. Then just give report to your tax person.
I'd forget excel cause you gotta build the sheet but with Quicken you don't have to do any type of programming. It guides you through setting up checking account, credit card account etc.
It will do lot of other fancy stuff like link to your bank and download all the info, credit card spending, check spending etc but I don't mess with that, rather just type it in myself. Some, probably most now, banks charge extra for that downloading, fyi.
One example of what I do is anything I buy via internet I put "Internet" in the Category column, doesn't matter if I write a check or pay with credit card. Then at tax time I have it print a report with all categories for check, credit card etc with "internet" in it and it gives me prntout of it with total and all. I give this to tax person. We have to pay sales tax on state return for those purchases and he uses that print out for that purpose.
I'm just too honest!
Don
Re: Tax Software
Re: Tax Software
>I'll work on Excell and Quicken to see what works for next year. The checking account is simple and falls into Excell without to much work. Now Paypal creates a page that is just huge with extra columns and rows that need to be removed... make one mistake and you start over. Everything goes through a card/check just so I have a record and the reciepts go into a box to keep it simple. Thank goodness this is only once a year.
Quickbooks didn't last long at all, it had to "update" the information all the time when all I did was put examples in the blanks. The last straw was when the program asked to backup the information online... I don't think so. Could you imagine the database they have... well the program was removed asap and they are on my spam list.
Re: Tax Software
Tony Reynolds
Re: Tax Software
Tony Reynolds
>Hi Doug,
I've been using QuickBooks Pro to run my business since 2005. It allows you to choose which type of business you want to set up. Retail, manufacturing etc. It is fully customizable as far as your chart of accounts etc. The online back up is an optional service they offer but it will also just backup to your internal or external drive or CD/DVD. I've never seen it consistently have to do updates as I enter info. At the end of the year or anytime it generates P/L statements either detailed or in general which are nice to see where you stand on a cash or accrual basis. It does lots of other financial type statements. It does have a little bit of a learning curve but nothing you couldn't handle. My CPA EA insists I use it. Just a happy user.
PS. Still loving my detail gouges.
Tony
Re: Tax Software
Re: Tax Software
Wilford Bickel
>Hi Doug,
I use Quickbooks Pro for the chemical company records at work and it does great. Will do Purchase orders, invoices, accept customer payments, lets you mark bills paid and do all sorts of reports - as to backing up to the internet and such that is up to you and you just have to set up the preferences like you want them. You have the freedom to do what you want - don't let it scare you when it asks about backing up to the internet just tell it NO and set up your own back up system.
We use Quicken 2004 here at home and have the farm and personal finances on it. It is a combination of quickbooks for business part and quicken for the personal check book. Have no problem with it and our CPA likes the reports the wife has produced and will take to him tomorrow - cutting it close this year, too much going on! Even with this one you have to set your own preferences to what you want the program to do - we back up to 3 1/4 floppy disks on this program and we like it so we just don't want to update. Since we don't do payrolls we have no reason to update to a newer version so why spend the money when I can use it to buy another Thompson gouge!
Re: Tax Software
Re: Tax Software
>I didn't purchase Quickbook Pro so that might work better. The books are basic, it's getting all the information to the accountant that's a killer... heck even my employee works for nothing (don't say a word he still thinks it's a fun hobby)
What surprised me this year is how the costs have gone up, steel of course, travel is a big one, mileage. I did upgrade one machine last year and one this year... both American made.
Re: Tax Software
Re: Tax Software
Dinyar Chavda
>Doug:
You mentioned that you would work on Excel and Quicken this year. Obviously, given that I don't know how you keep your books, I can't comment definitively, but it would seem to me that you should be able to work with just Quicken, and not have to use Excel also (I use Quickbook for business, and Quicken for home finances). That would make it easier to prepare information for your accountant, as you would not have to consolidate data from 2 sources. I use Quicken to download all my information from my bank, investments and credit cards, and it makes things go pretty fast. Quicken also lets you categorize and subcategorize your income and expenses, and link them to the relevant tax line (I haven't used this tax feature).
I agree it is a pita getting information from PayPal into Excel--I have to do it a couple of times a year for use tax. But Quicken will allow you to download this also. I haven't done this, but saw a reference to it at http://financialsoft.about.com/od/quickenforbeginners/f/Q_PayPalDownld.htm . Try it.
Finally, when I'm working with Quicken, I do backups as I finish each task (e.g., if I'm reconciling several months of financial statements, I will backup as I finish each month). That way, if I screw up on something, I can go back to a version that I know is right.
Hope this helps.
Re: Tax Software
Re: Tax Software *LINK*
Fred Holder
>Hello Doug,
I've been using Medlin Accounting software for about 20 years. It is easy to post to and it gives you a number or reports. I basically use the General Ledger for sales and expenses and the Accounts Receiving and Invoicing software for billing my advertisers. There is also an payroll software that I used when I owned a Printing Business and had a number of employees to make payroll on. If I remember right it also had the capability to print payroll checks, but I never used that capability.
Their web site is: www.medlin.com/.
As I recall it is about $50.00 per tax year for the complete updates of the program. It may be a free download to try it out. At least it use to be free for trial. I've had a number of other programs recommended to me, but I'm quite happy with Medlin.
Fred Holder, More Woodturning
More Woodturning Website
