Have you turned a fire piston?
JohnKyler
>Has anyone turned a fire piston? If so any lessons learned?
I want to turn a couple of these out for camping and would like any specifications for the plunger. It appears the plunger is 1/2" or least most seem to be, and I was thinking of a brass insert for the starter (end area) to prevent it from burning.
TIA
John
Re: Have you turned a fire piston?
Re:What the heck is a fire piston??
Jamie D
Steven Antonucci
It's a way to start a fire without match
steve antonucci
>Uses Boyle's Law to ignite tinder. Compress air in a tube, and it will raise the temperature enough to ignite the tinder.
I'll just carry a magnesium stick- that's enough like work for me...
S
Re: It's a way to start a fire without match
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>I had no idea there was such a thing! Fascinating! I imagine that the outdoor survival people would, or should, know all about these.
Re: This is amazing information! I have ....
Jamie D
>... never run across such info, especially while becoming a Boy Scout fire by friction champion or going thru Ranger school in the ARMY!
JohnKyler
>I saw it on a survivor show and was amazed. I also was intrigued by the history and connection to engines.
I'm going out to turn a couple of these today just because I want to see if I can make it work.
Re: We want to see photos John!!
Jamie D
type in 'fire piston' on YouTube
Ron Bauman
Bob Macgregor
>I wondered about this, too. Could the Scouts be behind the times?
I finally decided that the major factor is that you aren't likely to be able to cobble together a fire piston from raw materials if stranded in the wilderness, whereas the standard friction technique (eg with a fire bow) requires a lot less precisely-engineered tools. Not to mention the difficulty of liposuctioning fat from your dog in the field!
BOB
JohnKyler
>I was able to turn one yesterday.
Doesn't work yet.
So when I get more time for recreational turning, I will try again.
I will follow up.
John
