Have a question? Ask Woody!
Finishing Green Wood
Brad Vietje
Brad Vietje
>Hi All,
Marc Phillips asked a question about applying finish to a green-turned bowl. There are quite a few things to consider here, especially since most of us were taught that wood finishes -- especially oil finishes -- were not compatible with water (sap in the wood). Won't we get some sort of awful, smeared or spotty result? Well, not necessarily -- it depends on what you do.
I learned from two of my turning mentors, Luke Mann and Dustin Coates, that you can successfully apply at least some oil finishes to wood that still has quite a bit of moisture in it.
WHY would you want to do this? Well, consider a curly piece of crotch wood, or a green-turned burl. If you want to allow the wood to wrinkle as it dries, and accentuate the texture of the curly grain, you can sand the wood when it is still very wet, so it retains the crinkled surface after the wood dries, as opposed to sanding away all that lovely texture. The grain will be raised once its air-dried, but the surface can be smoothed with a soft abrasive pad like Scotch-Bright. I use little squares on my Velcro power sanding disks on the dry wood, which removes fuzz without destroying the textured surface. By wet sanding, I don't mean dry abrasive on damp wood, which simply clogs up in a few seconds.
To wet sand, protect your lathe from water, and use wet/dry sandpaper while constantly re-wetting the wood with water until the surface is real smooth. The dust becomes a slushy slurry that you rinse off into a bowl of water, which keeps all the dust out of the air. This is fun, but messy -- you will fling a band of sanding slurry up the wall, across the ceiling, and down your shirt front, so you need to dress accordingly and use plastic wherever you don't want gunk to fly and stick. Then you can towel off as much moisture as you can, and even air dry the surface before applying an oil finish. This can also be done with some oils instead of water, but I usually just use water for sanding up to 320 or 400, then dry the wood with towels, and apply oil to the surface by hand.
But WHY do this? Well the piece has to dry eventually, and it could develop cracks as it does, and the oil acts like Anchorseal, and helps slow down the moisture loss, so the wood can bend and distort without cracking. I've also used Butcher's paste wax here, then after air drying (for some weeks or months) I try to remove as much as I can with mineral spririts before adding an oil finish.
Which oils? I have used Urethane oil from Craft Supplies, as well as Watco Danish Oil, and have no idea if other oil finishes would work as well. I have also smeared on a coating of Tried & True Original (beeswax and raw linseed oil), which works well, but seems to stay tacky a lot longer. I leave the T&T on there overnight or so, then wipe off as much as I can with paper towels, and apply a little more every few weeks. I usually allow these things to dry for months, not days or weeks. Without taking some action, the wood will not be dry for a few months anyway, unless it is really thin. If I need a finished piece more quickly, I would do something else -- either try drying in the microwave, or grab a piece that was rough-turned a few years ago.
Another avenue is to air dry the piece after wet sanding (again, weeks or months, usually), remove the fuzz with a gray Scotch-Bright pad, and then apply oil to the dry wood. You will get better penetration, and quite possibly a more durable or harder finish, but you won't get the same protection from cracking that you get from slowing down the drying process by adding oil to the wet wood.
For natural-edge work, as in Marc's original question, I avoid using any sort of buffing wheel or pad, since the bark is so easily damaged. I also prefer a very low-luster finish for turnings with wrinkly texture, so I don't go for a glossy shine with white diamond and carnuba wax. I generally hand buff with paper towels, or very lightly buff with a little Tripoli added to a soft buffing wheel if there's not a fragile bark edge.
I'm certain that those who know lots more about wood finishing can add to this discussion, but this is what I do, and it does work.
Safe spinning,
Brad Vietje
Newbury, VT
Re: Finishing Green Wood
Marc Phillips
>I will be reading the replies to this carefully... as my bowls have improved I want to improve the finishing too... so just putting Briwax on it is not enough for me anymore...
.... watching closely!
