Sierra Click Button Pen (part deux)
Jim Rutten
>Ok. So I slept on it. And, as often happens when I sleep on things, I came up with a solution. My problem was that even though I had the nib on this pen protruding the correct amount of length when I clicked it to get it to go back into the pen or clicked it to come out of the pen it would stick once the button was depressed all of the way. I woke up convinced that the problem was the spring. So, I went through my wife's cup 'o pens she gets from going to nurses conferences and started looking at the springs in the click pens. Interestingly enough, EVERY single pen I looked at (remember these are give away pens) had a more robust spring in it then the one that came with the kit. Now it is a fine line because if you get too big of a spring the pen won't click at all. On the fourth try I found one that worked and now the pen clicks. Only problem is I bought ten of these kits and I am not sure I can find 40 click pens to salvage the springs from. Attached you will find a picture of the difference in the two springs and on the next message a picture of the functioning pen.
