>I once completely re-built a lab-grade Welsh vacuum pump back in the early 1980s - took apart the entire 'innards', cleaned all parts, de-rusted the various components, and re-assembled; quite a mess, but it worked like new. You will need to be a bit more specific as to the model number of the pump, motor horsepower, etc., since there are several different kinds of vacuum pumps manufactured by Welsh - it is (was?) a very popular lab item distributed by the Sergeant-Welsh Scientific Company. It may be possible to reference the model number information of the pump with replacement parts lists to ascertain the flow volume and maximum achievable vacuum for the pump you ask about. We can't do this from the limited information you have provided. Check for rating plates. or model numbers, etc. with this information on the body of the pump. Motor ratings are often on a plate near where the power cord enters the motor.
Can we assume this is an oil-jacketed, belt driven pump, or is it of the "dry", rotary-vane, direct-drive type? You'll need to report this information if anyone will be able to identify the operating parameters you are asking about.
Would like to try to help, but can't for lack of information.
Rob Wallace
PS: I re-built this Welsh vacuum pump at Rutgers University, New Brunswick, NJ - maybe it's the same pump I worked-on while a graduate student there?? ;^)
