>Now that I think the Nove is the best choice of lathe for me...
many "posts" to this and other forums say you don't need the outboard tool rest assembly. Can anyone explain why and what do you use in its place. Thanks again for all the responses to my last (first)question!
You can still turn with the regular tool rest with the headstock rotated out about 30 degrees and you can turn more diameter there than you can over the bed. Mostly that is useful for hollowing the bowl, where you can stand in front of your turning and not have to lean over the lathe bed. If you plan to turn really large diameter platters, etc. it would be a good idea to purchase the outboard tool rest which allows one to turn pieces up to about 29 inches in diameter. I think most people who purchase the outboard tool rest seldom use it. How many of us turn pieces 29 inches in diameter? Not many I would suspect and those who do probably want a heavier duty lathe like a Stubby.
>As others have pointed out, how often will you come across a piece of wood 29" in diameter? Logistically, the turning headstock is only good for about another 1" of swing, because the toolrest can't reach much further to the left. I made an "extended toolrest" for about $10 in parts.
>That is a great idea. I am planning to buy this same lathe and was I was going to get the too rest to go with it. Now I know better. I often buy the latest gaget to come out, but a number of times afterwards I find a simpler and CHEAPER way to do things just by reading and playing around with ideas.
>I do hobby turning and have very little use for the outboard rest. Steve's idea is great for the few times it will come up. Think about it. A 16" diameter bowl is huge. It won't fit in most cabinets, either kitchen cabinets for the practical bowl or display cabinets for the art bowl. Several turners I have talked to told me they seldom sell a bowl larger than 14". Richard Raffin was one of them. (His customers want a bowl that will fit in a suit case.)
I made a large bowl on my lathe and realized you can't really turn a 16" bowl on a 16" lathe. You would have to have a very well done blank to get even close. I hack out most of my blanks with a chainsaw. If I were to be really careful I might get a 15" bowl out of a multi sided blank. You have to have enough swing to knock the corners off. I wanted to get the max out of two blanks, so I mounted them with the head swiveled to the side and ran the lathe backwards long enough to rough the rim of the bowls. Made sure the set screws on the chuck were carefully engaged. The bowls are about 15 3/4". You could make salad for the army in one of them.
>If you look at the picture above, you'll see a variety of "knockout" for a quick and easy shelf. I did go back and add one almost immediately, so this picture was probably taken right after I bought the lathe. The shelf has a bottom and a top and is filled with gravel between.
>The outboard tool rest for the 16/42 is a joke. It does work for some things but it vibrates too much. I had to put a piece of all thread rod going from the floor to the tool rest to get it to be solid. When I tried to use it I often couldn't get the tool rest in the right position without removing the piece I was turning, adjust the tool rest and then put it back on. That was a pain.
>Funny John, other than those who bought it and never use it, that's the first negative I've ever heard about the Nova outboard rig. I considered getting one but haven't so far. One of these days, I will set up something like Steve A's.
