Glue Blocks
Glue Blocks
Glue Blocks
DC Powers
>What types of woods are good for glue blocks?
Does it need to be dry?
How thick do they have to be?
I'm assuming I need dry wood and am having trouble
an inexpensive source.
Any ideas are appreciated.
Re: Glue Blocks
Re: Glue Blocks
DavidWalser
>I've had very good success using 2x4 or 2x6 lumber from the home center for my glue blocks. After jointing one face flat, I use a 3.5" or 4" hole saw to cut the blocks out of the lumber. The hole left by the hole saw's drill center helps me to center the glue blocks onto the face plate. It's quick and inexpensive. I've not had any problem with the glue blocks splitting and allowing the turning to become an unguided missile flying off the lathe. But, then, I've not used them with anything really large, either.
Re: Glue Blocks
glue blocks
Philip Duffy
>I go to the local custom cabinet shop and for a "donation to the coffee mess" get to pick up shorts of hard woods that I turn to my needed sizes. Often times I walk out with 4 or 5 planks of oak or popular that is 5-8 in wide and 20 in long. Great stuff! Philip
Re: Glue Blocks
Re: Glue Blocks
Jennifer@Indy.USA
>Most straight grain woods will work fine. Soft maple, alder,poplar are all good inexpensive choices. I'd go with 2" thick material to give you room for screws and then parting off. I would also use a good quality sheet metal screw with deep threads whenever using a faceplae too. Never drywall screws.
Jen
Re: Glue Blocks
Re: Glue Blocks
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>For what it's worth I remember Cindy Drozda saying that the type of wood for glue blocks is important. I don't remember all the ones she recommended , but one of them was mahogany. My own feeling is NOT to use soft woods because they will distort under pressure if you decide to use a chuck. I even remember a well-know turner demonstrating at an AAW symposium -- I think in Kansas City -- who mistakenly brought along a too-soft wood for his glue block and had to give up on his demo because he found that the block distorted too much in his chuck.
Re: Glue Blocks
Re: Glue Blocks
bill Crommett
>I use Red Oak, but that is because I have whole pile of Oak lumber out back that I had milled out when we cut out the footprint of the house. BUT I prefer Yellow Poplar.
Re: Glue Blocks
I use poplar
keith zimmerman, Normal IL
Re: Glue Blocks
Re: Glue Blocks
>I like to use dry poplar, oak, or other hardwood. I don't like cedar or pine as much since it compresses with the chuck jaws and cedar doesn't hold screws as well.
A 3/4" board is often thick enough, but I usually grip with a chuck rather than screws/faceplate. A board planed on at least one side is nicer than rough cut for gluing.
Anyone who does flat woodworking will likely have free offcuts or scraps. The borg or lumberyard sometimes has inexpensive short pieces or suitable rejects. If you live near or pass through East TN, I'll gladly run a dry poplar or cherry board through the planer for you.
Re: Glue Blocks
Re: Glue Blocks
DC Powers
>Thanks John. I always enjoy the responses on here.
Thanks for the offer. If I get to Tennessee, I'll
look you up.
Re: Glue Blocks
Free, but a lot of work......
>You could find a pallet or two that were made of hardwood. Tear them apart and use the frame members to make glue blocks. The hard work would be getting the nails out. Once the nails are out, piece of cake. There is all kinds of dunnage around construction sites. Recently grabbed some 4x4's of oak that had been under pipe. Free, and this time no nails. They were not well dried, but there would have been a ton of glue blocks in them.
Re: Glue Blocks
Re: Glue Blocks
Frank C. Joseph
>I have a co. that makes roof truss. They have tons of cutoffs
2x6, 2x8, and 2x10s from 10 to 20 inches Free
Re: Glue Blocks
Re: Glue Blocks
jim miles - Charlote NC
>Don't use plywood, it comes apart, I had a bad time with western red cedar
About 2" thick is good with faceplate- that allows you to use 1 or 1-1/4 screws and still have room turn down the glue block and work on the base of the piece. If using faceplate, most any wood will work, avoid knots, checks & cracks. Pine 2 x 4, 2x6s etc work fine. Stop by any residential construction site and they will give you all you can haul away, might have to pull a few nails. I do 95% of my work on glue blocks - up to 24"
