shellac and alcohols
Claudia Hayward
>I've never used shellac before and have been doing some reading in the archives (there's some great information there!). My main use for it is to seal the wood before I colour things with dye. I'm a bit confused by just what sort of alcohol the flakes can be dissolved in. Denatured alcohol seems to be the choice. What I have on hand is isopropyl alcohol (rubbing alcohol), lacquer thinner and mineral spirits. Can I use any of those nor do I need to go buy the denatured alcohol?
Re: shellac and alcohols
Michael Stadulis in Southern NJ------WebKitFormBou
>Claudia,
The issue is that some alcohols have more water in them. Use denatured. I use the kind at the borgs and it woorks fine. Have never tried Behkol which supposedly has the least water in it.
Mike
Bill Clark
>I gave up on shellac flakes. Too messy and the shelf life was short once I mixed it. I now use Zinsser "Bulls Eye SealCoat". It's a one pound cut and is perfect for sealing under any finish. There's no wax, minimum color change and it lasts for over a year in a partially opened can. You can put any finish over it. My favorite is MinWax Wipe-On-Poly. Lowes and Home Depot both carry it. Great stuff.
Rob Wallace
Rob Wallace
>Claudia:
You should use denatured alcohol to dissolve shellac. The isopropyl alcohol you likely have available (unless it is from a laboratory or industrial source) sold as "rubbing" alcohol is typically 15-30% water - and not compatible with shellac flakes or pre-mixed shellac finishes. Denatured alcohol (usually at least 95% ethanol) is the preferred kind of alcohol for shellac, which is "denatured' with other organic solvents (such as methanol) to make it "undrinkable, and hence, not taxable under BATF/liquor laws. Do not use mineral spirits or lacquer thinner for shellac - unnecessary and these have some chemical incompatibilties that you need not get into.
In contrast with Bill, I routinely use shellac flakes, which provides me with an excellent sanding sealer and wood 'stabilizer' that does not change the wood color appreciably, if at all. I mix only as much dissolved shellac flakes as I need (typically in 8 liquid ounce aliquots), and I tend to use it up before it has a chance to "go bad". I purchase de-waxed, ultra-blonde shellac flakes and use a 1-pound coat of this finish as a "universal" undercoat for all pieces that will receive a subsequent film finish (typically sprayed lacquer, or water-based polyurethane). I do not use shellac when the finish is to be oil-based (e.g. Watco, tung oil, Minwax Antique oil finish, walnut oil, etc.)
In short, shellac is an excellent finish, and is one of the natural resins found in "woodturners finishes" such as those from Behlen, or in Myland's Friction Polish.
Good luck with your finishing - the learning curve flattens out pretty quickly with lots of practice.
Rob Wallace
Bill Howatt
>Do not use methanol also known as methyl hydrate or wood alcohol. It will dissolve the flakes OK but it is bad for your health. It is known to cause neurological problems.
You may find that the denatured alcohol has been denatured by a bit of methanol, not ideal but much better than pure methanol.
Ethanol, which is the kind of alcohol you can drink is rendered undrinkable (poisonous) by adding something noxious and this is where the term denatured comes from. There are numerous chemicals used to perform the denaturing function.
Bill
Jesper, Denmark
Re: What they said and......
Jesper, Denmark
>The denaturant is normally MEK, Methyl Ethyl Ketone, not methanol. The alcohol should be at least 93% alcohol/denaturant and the rest is water.
Rubbing alcohol is iso-Propanol with 30% water and is no good for this.
Bruce McElhaney, Spring Lake, Michigan
>Good advice so far. Shellac is great sealer and dries fast. I normally use super-blond shellac flakes, (only with denatured alcohol) but mixing can be a bit time consuming. I occasionally use Zinsser Clear Shellac in the can. It works just as well and has a good shelf life. It can be thinned a bit for sealing if desired. Zinsser shellac sanding sealer is also a good choice for sealing as the cut is a bit thinner. BTW, The dates are always stamped on the can.
Claudia Hayward
>Thanks everyone - I sure appreciate the help!
Alex Yeilding
>I second the recommendation of Zinsser SealCoat. I still use flakes for a final finish, or when I want to add color in the sealing process (I keep a batch of garnet on hand for that). But for basic sealing, SealCoat is hard to beat. Good shelf life, and dewaxed. Be careful with any other prepared shellac. Most are not dewaxed. I found that the aerosol of Zinsser's Clear Shellac is dewaxed, but the cans are not. This is important if you use poly, and possibly for other finishes. You'll see the cans other than SealCoat warning against use under poly.
R Payne
>Since I didn't see anyone else mention it, I will. You can also use "pure" ethanol. Think everclear. I put pure in quotes because it is typically 95% ethanol with the balance being water.
ron
Jesper, Denmark
Re: Trivial pursuit.........
Jesper, Denmark
>The reason ethanol mostly is 95% Ethanol and 5% water is that they form an azeotrope. Go ahead and Google it!.
When you boil ethanol in the distillation column to concentrate it, it has the property that the vapor always is 95% ethanol and 5% water. You cannot distill ethanol to more purity without some complex and expensive chemical treatment or co-distilling with other solvents.
