Vacuum Pressure Loss
bowlman
>I just attempted to add filters to my vacuum chuck system. Based on someone's advice (don't remember who), I purchased 2 inline filters from Harbor Freight. Put one on the tube between the pump and the chuck and the other on the end of the relief valve. So now, the vacuum only draws 10 before it drew 25 consistently (no filters). All brass connections, teflon tape, etc.
Took everything off, back to original no-filter configuration ... 25 again. Put the filter back on the end of the relief valve ... draws 25 ... BUT ... when relief valve is open, vacuum only drops to 10 ... I expected it to drop to zero.
What gives? All advice greatly appreciated.
Re: Vacuum Pressure Loss
Don Evans
>Having a filter between the pump and the spindle (chuck) is a very good idea. Some filters have an input and output and in this case you would want the input going to the chuck and output going to the pump.
If that is correct, I'll assume you know how to make the fittings tight enough as you can draw 25, so I would blame the filter itself. Give link to the HF filter so can look at it...
I do not see any need for a filter on the output of the relief valve (ball valve). I noticed Carol has one also. That filter should go onto the output of the pump to cut down on noise. The fact that you can open the relief ball valve and still have 10 hg is very puzzling and makes me wonder if that filter is defect, plugged up somehow. How about a couple of pictures?
Only possible reason for have the filter on ball valve may be that you are running an "oil" pump and trying to keep that out of shop, but if that is the case, it should be piped outside and the pump output port should also be piped outside.
Are you running a vane oilLESS pump like a Gast or some other pump with an oil resevior?
Don
bowlman
>Pump is a Gast, just like they sell at OneWay and Craft Supplies. Pics to follow.
Rick Allen
>Hi Don,
There are two possible sources for dust to enter the pump. One is the chuck vacuum lime. The other is the valve used to adjust the amount of vacuum.
The filter restricting the otherwise unimpeded air flow to 10 sounds normal to me.
bowlman
>Here is a shot of the filter, model number 94733, Central Pneumatic Mini Inline Dryer/Filter.
Chuck is to the left, pump to right, airflow is left to right.
Cyril Griesbach
>Bowlman, I can't help you with this problem other than to say that I've always thought of "Vacuum Pressure" to be an oxymoron if you think about it.
PS: I haven't forgotten about the off center information you want but I just haven't gotten it back yet. When I do I'll send it on.
Bob Lemon, Sacramento CA
>Get yourself a wound yarn water filter. I've been using one for about 10 years now. It does a great job and passes a lot of air. Mine has a 3/4 inch female thread on both sides - in and out. The bowl comes off so you can replace the filter element. They are not expensive.
Carol - now back in Dubuque, IA
>If that bowl has a rubber o-ring, just take it apart, wet the o-ring (spit works) and immediately reassemble it.
That's where I always found a leak when the filter got put in the system.
And that's what cured it.
Bill Clark
>Looks like your filter is too small and not able to handle the volume of air you're pulling. Since you pull a good vacuum w/o the filter try a larger filter. Mine are large auto fuel filters that are about 3" in diameter.
V
>Dick if it is like Oneway pump and has 2 black caps on the end ,take those out ,they are filters.
Don Evans
>Rick, that makes good sense. Duh, I just had not considered that it is sucking air in at that point! Funny how the mind works or doesn't work sometimes.
Thanks.
Don
Re: Vacuum Loss
Bill Turpin in WNC mountains
>Vacuum volume (CFM)is inversely proportional to the square of the distance or area. TRANSLATION: double the length of piping = 1/4 the volume sucked. Halve the piping diameter or smallest orifice = 1/4 the volume. You could be losing a tremendous amount of suction in a small diameter filter.
Automotive filter
Jorge Castaneda~Downeast Maine
>I used an automotive online gasoline filter from the local parts store, and the pressure did drop from 29 to 26, but other than that it works just fine. My pump is a Robin air, an oil pump.
