>I want to buy a respirator that I could use during sanding and, occasionally, turning. I would prefer something compact enough that I could wear under my face shield, although this is not strictly necessary.
I am not looking to buy an expensive system like Triton, just something better than dust masks that do not seem to do a whole lot.
Those models that I found in HDepot and Lowes seems to be geared toward painters. Can you recommend something similar but better suited for woodworking?
>A.O. Smith brand is good as any. However you want the one that has the screw on and off filters (round ones).
They come in different sizes so get one that fits well..
Here is the most important part: They make different filters for this mask depending on what you are filtering determines what filter to use. You can also gang the filters, one screwed onto the other.
You use there particle filter for wood dust etc.
Then you can switch filter cartrige if painting and use filter for that is made for painting. Also this same mask can be used for pesticide spraying with correct filter.
To test the fit, put mask on adj straps and pull them snug. Place hand over the filters and try to breath in, if there is no leak you have a good fitting one. You'll have no trouble telling as you should be able to suck the mask inward and get NO air.
Barbara Gill------WebKitFormBoundarypTwA+e87REJF0d
Guest
Re: Can you suggest a respirator?
>Both North and 3M make a mask that uses screw on dust filters which are extremely effective. I am not at my home computer so I can't give you site information.
If you do a search of the Turning archives for posts by me you will probably find the li
links.
I have used the North in the sawmill since 1986. I use the North under my faceshield with no problem.
>I use one called the Resp-O-Rator and really like it. I wear it under my full face shield. It has no batteries to run down, weighs about 7 oz. and filters down do 3 microns at 99.97% efficiency. It has a mouthpiece and 2 tubes that rest on your shoulders and the filters are behind your head. They cost about $50 but Hartville Tool runs them on special with a face mask every so often. You can also get them at Woodcraft, Woodworker's Supply or Klingspore. The website is www.resp-o-rator.com. I don't have any financial interest in the product. I just use it and I like it better than anything else I have tried.
>Why not srpng for a shield and respirator all in one. The Trend Pro is on sale at allprotools for $269. Filters to lower micon units (see specs). Fan runs 8 hours. The old Trend is not nearly as good but it is on sale for $229. Rather than fight with two things just use the one helmet it is easy to get used to.
>You can also try Lab Safety Supply Company - they have a huge line of industrial grade respirators for most common particulate and many chemical contaminants. In addition to actual repirators, they also sell powered, filtered-air facemasks, as well as nuisance particulate filters rated for different micron sizes of contaminating materials.
The have an on-line catalog, etc. at the link supplied below...
