Another use for the Nova outboard rig
Carole Valentine
>I had decided the outboard rig I ordered when I got my Nova DVR was a waste of money, but along the way I have found tons of uses for it...none of them the intended use, of course. Here is the latest. I kept the steel rod from my bandsaw when I put the riser block on. Knew it would come in handy someday. (yeah, I'm a packrat!) Just so happens it fits right in the hole for the tool post on the outrigger. So...I made a crude but rock solid control center for the vac system and I can swing it all out of the way when I am not using it or take it out of the post altogether.
Re: Another use for the Nova outboard rig
Jim Shaver - Oakville, Ont
>Nice work Carole,
Jim
Very original Carol
Al Neighbors
>That's using the old bean, Carole! :o)
paul waddle
>Good I idea,but I kept my bandsaw "pole"intact. I started to use it for a shaft,but decided the flat didn't suit. pw
Carole Valentine
>If you are a true packrat, you'll find a use for it, Paul! Don't throw it away. In this case the flat turned out to be an asset.
George Van Beynen
>I must be a "true" packrat Carol. I will be starting the addition on the 40'x63' pole building shortly!
