Bad Day Turning
Bad Day Turning
Bad Day Turning
Carl Barton
>Did you ever have one of those days that nothing you tried just did not work out? For the last three days I spent my time gluing up 1/2in sq blocks of different woods, seven per row, seven rows, each 6in. long. My intent was to make a lidded box from laminated woods. I sanded each block on all four sides so they would fit just perfectly, this was the first time this portion of my laminated projects came out right.I have done a number of laminated projects, with each one I have been doing better and better.
Today all that hard work went down the drain. Even now after a couple of hours after I finished the project I am still trying to figure out what I did that caused my box to go south. The lid did not fit properly, shape not right, and the centering of the laminated blocks on the top did not center the way I wanted it too. LOML says it was not so bad, but I still think it did not turn out very well at all.
I have only been turing for two years and today if felt like I just turned for the first time.
Thanks for letting me vent, at least I feel a little bit better.
Carl
Re: Bad Day Turning
Re: Bad Day Turning
GalenV in Iowa
>Carl
You are out more time and effort than I am so I guess I should not complain.
I was down crawling around in the wood chips looking for a set screw that came out of a bushing I was using on the lathe. Even dug into the shop vac trying to use a magnet to pick it up.
After my knees got to hurting I went to the ACE Hardware and bought two. Probably will forget what I did with the spare when I need it again.
Hey on the bright side you could have been working on a segmented piece with 500 pieces and I cannot imagine what a turner feels like when he or she slips up on one of those!
Galen
Re: Bad Day Turning
Re: Bad Day Turning
Carl Barton
>Galen,
OOOOO, I know how that feels to loose something in the wood chips. You are correct, if I had messed up a 500 peice segmented bowl I would really have been crying in my sawdust. Of course there is still time for me to do that as well. I have a segmented bowl just waiting for me to stack and turn. While not a 500 peice I would still be upset. It is only about 80 peices. Someone is going to get a maple with a canery wood feature ring cookie jar for Chirstmas, that is if the LOML does not grab it first. But I think I will hold off doing this project for a few days, in case I am still having more of the same day as today.
Carl
Re: Bad Day Turning
Re: Bad Day Turning
Barry Elder
>I can agree with the bad day turning after making a funnel, ripping most of the fingernail off my index finger, which prompted many bad bad words! But....a bad day turning is still wwwaaaaaayyyyyy better than going to work!!!! And tomorrow is a better day, just wait and see!!
