Vac Chuck question
John Veerkamp,Western Mo
>Last night's chat raised a question in my mind. Does a vac addapter like Carole's(or any one else's) interfere with the knock out rod used to remove morse taper items from the headstock?
John
Vac Chuck question
John
Re: Vac Chuck question
Don Evans
>John:
Yes, they have to seal up the end of the spindle in order to keep the vacuum up.
One could design a nut release (calling it that for lack of better name) that could screw onto the other end of the spindle before you insert the MT. Then when you want to remove the MT it's design would be so that it pushes against a collar on the MT as you unscrew the nut.
What you will more than likely find is that this isn't really that great a problem simply because I and I assume most who have vac systems remove the addapter when not using it. If for not other reason there is no need to put wear on it when doing turning that doesn't require the vacuum system.
I use the "oneway" adapter and I remove it from the spindle when not in use.
Don
Mfoster
>I am in the process of rebuilding a vacuum adapter for my lathe that allows one to keep the adapter on the lathe, yet still use the knock-out bar. I expect to complete it this weekend and will post pics of the result. I have used one for years and it works fine.
Don Evans
>Yep, I thought of a way to do that while writing message above but didn't think it would be worth the trouble as I'm gonna remove to save bearings anyway.
A hollow knock out bar with built in "T" for the vac would work.
Interested to see what you have come up with.
Don
Carole Valentine
>It's really no problem since you would not be using the knockout bar while you are using the vac anyway. I don't have to unscrew anything to put my adapter on and off the lathe...I just pop it in and pull it out when I am through. It is a fairly easy fit into my handwheel...the vac draws it down tight so it's not going to come out when the system is on. Jeff has the same type on his Jet Mini. Don't know if it would have to be different on other lathes or not...would depend on the handwheel.
Thanks all
