>At tonight's turning club meeting, a member let us in on a new finishing tip he came acrossed.
A tenant had moved out of his rental, and while cleaning out stuff she'd left behind he found - wait for it - a box of panty liners. Always on the look out for finish applicators, and being somewhat frugal - he tried one to apply the finish to a piece on his lathe.
Worked great - not abbrassive like some paper towels, the finish stays in it or on the piece - no drips or runs - the outside is an impervious membrane so no finish gets on his fingers - AND - the outside surface has a semi-adhesive on it so it sticks to your hand - but comes off easily without removing skin.
Learn something new every day - some quite surprising - and unusual. Who'd of thunk it!
Interesting, but there's no way I'm going to use those in my studio... Down in Texas, they might hang you for that... No way, No how, Not going to happen... :-o
Better Woodturning and Finishing Through Chemistry...
>These super absorbant materials can waste a lot of finishing liquid. They are made to absorb and hold a large volume of liquid. While they may have good wiping characteristics, they don't give up the liquid easilly. Thats what they are supposed to do.
>That's true enough Russ, but I see the possibility with the right applicator attached to "meter" the finish out as you apply. Think about a roller thingy like used for tubes like toothpaste. As example.
I like many others, use a similar method when using shellac but it was much simpler.
a cotton cloth folded several times with shellac in center (inside) the folds.
>Something I was shown years ago was to use makeup remover pads in Europe these are round disks about 1.5" in diameter and they have a rough and smooth side. They are great for applying friction polish and then buffing it. They are not as absorbent as the original suggestion but they work well in my experience, they are cheap and unlike the other suggestion don't get unusual looks when you buy them. ;)
>I am reminded of the story the comedian Yakov Smirnoff tells about the first dinner party he hosted where he used wrapped napkins on the table because the box indicated that they were sanitary....
He went on to say that his guests all went bleagh-h-h-h upon seeing them on the table...
>For those who don't want to be seen shopping in the cosmetic department, the pads are available from your friendly Woodcraft store for 5 times the price. Wherever you buy them, they do work better than an old T-shirt or sock.
