preventing ca glue bleeding
Lan Brady
>I wanted to try a technique to block ca glue from bleeding when used to fill a crack. It was suggested to use a dilute solution of shellac.
I needed a mister bottle. The only one I could find was with hair spray.
You guessed it, I had to try!!!! I used the hairspray on the piece and it worked great.
What is that stuff?
Was it just a coincidence that it worked so well?
I am easily amazed!, Lan
