Turning Attachment
Don wilcut
>Any comments, good or bad, on the Eccentric Turning Attachment Ken Grunke manufactures?
Turning Attachment
Don wilcut
Re: Turning Attachment
>Do you have a link. I tried to go to his website and couldn't find the eccentric chuck.
Dale Cook
>Hi John, I googled ken grunke woodturner and (ken grunke:shop) came up first and you can see chuck at the bottom of the page.
thanks Dale
>I remember that chuck now. It only works in 2 planes but is much simpler than the others. I'm wondering how hard it would be to put 2 tapered wedges underneath it. These could have slots cut in them so that you by rotating them opposite each other you could have a limited movement of a 3rd axis. Kind of like a Wobble Dado blade.
Rich Egan
>Don: Ken is a member of our local club, and I own one of his chucks. I have only used it a few times, but it seems to work well within its limitations. It's designed to work with a scroll chuck, which most turners already have. You can shift the work off-center, but parallel to the axis. By doing that, and rotating the work, you can create some interesting twisted spiral designs. You'll want good solid material, as it attaches with a screw, and it leaves a 3/8" hole, unless you fill that or part it away. Maximum length is around 6-8" in my experience. It is a well-constructed device, and a good value for the price. Ken is a good guy and will help you with any problems.
Rich
