>Okay, I have a bunch of turnings that haven't sold or been given away and no longer want to display them in favor of newer pieces. The shop is always dusty and cluttered so I do think shelving them out there is a good idea. I've got all the pieces on digital so can still create a portfolio. So, I need to pack them up in boxes. What can I use for packing material that won't harm the finishes? The finishes range from lacquer,waterlox,tung oil,poly,mineral oil.
My intent is to wrap them up then use bubble-wrap to protect them from dents/scapes.
>Wrap them in paper. I use the kind you get at the wrapping stores. It's white and quite soft. Do not wrap lacquer pieces in bubble wrap. I learned this from a professional who learned it the hard way. Bubble wrap over the tissue will work fine.
>Exactly ditto what John said.... ...buy bulk packs of white paper from shipping or moving supply stores (the plain, unprinted kind they wrap ceramic bowls and plates in for moving). .....this is mostly to keep any plastics off of the finishes. This kind of paper should not damage the finishes you mention as contact with plastics could. DO NOT use newspapers!
Why are you then wrapping these pieces in bubble wrap if you are just storing them? Do you expect them to be moved or physically bounced into one another? I think this an unnecessary expense (time and money) unless you have to pull a piece off the shelf and get it into a box to ship very quickly....
Regardless, be sure the finishes are "dry" and well-cured before wrapping in anything..... mineral oil finishes will never dry or cure, so be ready for 'bleed' if the oil is recently applied.
>Wrap in paper, put in a box and attach a picture of the pieces which are in the box. When you have to hunt something down you won't be opening boxes and unwrapping stuff to get the piece you want.
You can keep an inventory, but identifying the objects at place of storage will make your life easier in the years to come.
>Chip, When I started producing large numbers of turnings for shows , etc. I needed something also. My wife gathered a bunch of old sweat shirts from the kids and grandkids. She cut the arms off of the shirts which I use for storing turnings. I also use them for transporting to shows. I also use some of the bodys for larger turnings. They all work great. When I sell or ship pieces I put them in bubblewrap bags.
>Chip, The first layer of wrap should be white, acid-free tissue paper, leaving no finished surface exposed to the bubble wrap. I have boxes of stuff that may sit for months between shows. Each box is numbered and inventoried, sealed with packing tape to exclude the dust.
>Man, I wish you guys were around for Christmas 2007. Just finished a bowl for my MIL with Watco penetrating oil. Had about 24 hours to dry and we bubble wrapped it and the Christmas wrapped it. When she got it out it had dimples (or what looked like them) everywhere the bubble wrap touched. Still would like to know what chemical process caused that. BEWARE THE EVIL BUBBLEWRAP!!!
>I have used newspaper and never had a problem with it. is there something I am missing and should know about this? I dont want to have a bunch of turnings go bad. Thanks Jared
>Depending on what residual solvents may be present in the piece, or what waxes, etc. may be applied on top of a film finish, you are asking for transfer of newspaper inks to the surface of your turned piece. This has happened to me when a piece was wrapped in newsprint. This is the reason for recommending the white, unprinted paper.
Fortunately, the newsprint ink did not penetrate very far into the finish (likely was only on the surface), and after taking it back to the buffing wheels with tripoli and white diamond, I was able to buff away all of the ink-stained parts, and put on another coat of carnauba wax.
