Photo comments Please
Bruce
>Here is a photo using the frugal photo setup and a point and shoot.
This is a natural edge Bradford Pear bowl 6x5.5x3.5 inches tall.
I am looking for comments on the bowl and the photo.
Thanks
Bruce
Re: Photo comments Please
Norm Smith
>Hi Bruce. The bowl looks great to me. I find that the hardest part with a piece like this is keeping the bark in place.
Nice work,
Norm
Bruce Forrest
>Nice bowl. My only suggestion for the photo is that it's cropped a bit tight.
George Van Beynen
>Great job on the bowl Bruce. This is a good photo. Other than the cropping issue Bruce mentioned it appears the contrast on this shot could be increased. Correct me if I am wrong but it appears to me that the light source is directly to the left side and perhaps slightly to the rear? This photo may improve if the bowl were moved back to allow more light to hit the front and interior of the bowl.
Re: George has started you on the .......
Jamie D
>...right track, as you have more light on the background than on the turning. Place the turning toward the rear or move the light forward, or both! You could achieve more depth of field by remembering to focus on a spot 1/3rds from the front and 2/3rds from the rear of the turning, and this requires manual focus control on the camera. Your exposure is excellent, so adjusting the lighting and a bit less crop on the edges will make you look like a Phrugal Photo pro!
Bruce
>Thanks for the responses and advice. We will give it another go a see if we can make it better. I have to laugh about lighting behind the bowl. I think it was either Jamie or John L. that commented on this puzzling phenomenon. Well, I have now added to your head scratching observations.
Re: Bruce-if you will email me a photo....
Jamie D
>...of your set-up I can better recommend constructive changes.
Toney Robertson
>What f-stop are you using. It appears that the back of the bowl is not in focus. I would guess your f-stop was about 2. I use 6.3 (so people go higher even still) which helps keep the whole bowl in focus most of the time.
I would get a graduated background. It is amazing how that alone will make a huge difference in your photos.
Are you using the timer on the camera. If not, you should. Once again it is amazing how much pushing that little button can cause blur on the picture.
I assume that you are using a tripod. It is a must, IMO.
Take advantage of the digital part of photography and take a LOT of pictures. Change the settings, play with post production and see what works for you.
By the way, that is a very nice bowl.
Hope this helps.
Toney
Texian
>Very nice bowl! If you lack manual control of f-stop and exposure, can increase depth of field by moving the camera back and optical zoom in.
Ditto what Jamie just said.
Bruce
>Thanks Jamie
Re: Ditto what Jamie just said.
Bruce
>Thanks John.
