Have Laser? Use IT (dummy)!
charlie belden
>Finally had some green wood big enough to use the MiniMonster on for a Mini lathe sized hollow form - in California Pepper. Had some pieces with pretty dark heartwood (or it could be spalting - though I don't know if pepper spalts).
Had to cut some of the HSS cutter off in order to get the "angled head"in the 1" opening. Had to borrow a neighbor's grinder, with a cut off disk to do it and on the way to returning the grinder remembered that I actually have one - and know where it is.
The MiniMonster was doing a great job - too great a job when I got a little carried away near the end of hollowing - WITHOUT THE LASER.
Now it's not like mounting the laser and setting it up is some kind of PITA - it isn't - at all. And once set up - it stays there - even if the ride gets a little bumpy.
In retrospect, I do recall thinking "I should probably put the laser on now that I'm getting close - but . . .".
Thankfully, I have a few more blanks of this stuff - and one's on the lathe now. Put the laser on - and found I'd left it on since playing with it - five months ago.
The neck on this thing was left thick so there'd be some meat for reverse chucking to work on the bottom. Once that had been done I'd planned on finishing the neck.
Better luck next time - with the laser of course.
