Shop made vac adaptor
Carole Valentine
>Jeff made an adapter for his Jet Mini so I decided to do the same. This is a prototype, but it works so well that I am in no hurry to make a final version. I am drawing 25.1" with it. I hated fooling with the lamp rod on the Holdfast. I turned the adapter out of cherry so it would be a really snug fit inside my handwheel once it had the foamie (neoprene) on it. It extends past all the holes in the Nova handwheel. The walnut wheel is an afterthought to make it easier to remove the adapter from the lathe. The next one will be turned in one piece with a good grip! The brass Hex Nipple was filed to fit the inside of the bearing and attached with JB Weld, then the bearing was epoxied into the cherry. All the fittings except the bearing are from Lowes. The wood parts have 2 coats of poly to seal them (before installing the bearing)
