What techniques do you use when drying vases from green wood. I often rough turn my bowls but vases seem to be a different animal. Mine have been cracking around the bottom but I am open to any and all suggestions.
>It would help if I knew more than it is a "vase". i will assume the following - -- You are turning the vase end grain, you are leaving it oversizes so you can come back and turn it to finished dimension after it has dried, you are leaving the pith in the center of the bottom, you are leaving a chucking spigot on the bottom so you can come bach after it is dry and have something to hold onto. Bottom cracking is always a problem when you are doing all of these things.
Try turning the vase to finish size while it is still wet. If it is sort of concentric around the pith, there will be very little movement other than shrinking in diameter. The thinner wall thickness will have less crcaking.
Make sure the pith is in the center in the bottom. Then drill out the pith with a 1/2" to 3/4" drill. Save a twig from the same tree and use that to fill the hole afterwards. Or just use any piece of wood that has a sort of grain match. Nobody will see it anyway.
Or, just let it crack as it wants to and fill it with sanding dust from a darker wood, or artists charcoal, after it is dry. It will add a nice feature.
Some claim success with saturating the bottom with thin CA glue, inside and out. This has never worked for me, but that doesn't mean it won't work for others.
A thicker bottom will always crack. Take off the chucking spigot, and leave the bottom the same thickness as the rest of the vase with no more than an extra 1/8" for finishing the bottom later. If you need a chucking spigot later for holding the vase, then glue it on after it has dried. Epoxy is good for this because it fills gaps and the fit can be kinda sloppy.
Ignore what I said about the pith if you are turning it with the grain across the lathe bed, or the grain is in the long direction and there is no pith; and don't drill the hole in the center. Everything else stays the same.
Russ, you were correct in your assumptions. Those are all true. I am going to try some of those suggestions to see if I can get through some with fewer or no cracks.
I am also going to try turning one to finished thickness and see how that works.
>Jay,I turn small natural-edge vases, centered on the pith, from green madrone and green manzanita, both of which are prone to cracking. I agree with Dick that uniform thin walls are essential. For further safety, I use a deeply dished bottom rather than a flat bottom so that the stress between the pith and the sapwood at the bottom can be relieved by bending of the wood rather than by splitting. I use a foot, and back hollow the foot to match the dish shape of the bottom. Dennis
>Dennis nailed as well as Russ. This is what I learned from Dave Barriger many years ago. A cone shape will elongate as it shrinks which relieves the stresses. If you hollow the base and make that less than flat it will do the same. You may have to sand it flat after it dries to make it sit level.
Following Russ's advice about the pith, When I first put a log on the lathe and true up the ends I part off a section to be used to fill the pith area. I put this in a plastic bag and then flip the bag inside out every day. This allows the plug to dry slowly and not crack. It does take a while to dry however so you have to be patient to do this. I use this to fill the hole you drill through the pith. After the piece has dried I true up the hole that warped oval. Then I turn the dry plug piece to match and glue it with the grain aligned. Now you have a plug that is invisible if you disquise the glue joint with a slight V groove.
>I dry them the same way I dry my bowls. I wrap a couple of layers of the 6 inch plastic stretch film (the stuff you wrap around boxes on a pallet)around the outside, leave enough around the bottom to cover most of it, and make sure to get some covering the rim of the vase. Stretch it as you wrap. You can also use newspaper for the outside, and secure it to the rim with the plastic. Do leave the inside open.I have had great success with this method, even on the most difficult woods like Madrone. The piece dries from the inside out, and with the pressure from the stretched plastic, it is in compression.
>I really like this idea too. I'll give this a shot as well. I was doing a similar process with the anchorseal. I was just putting it on the outside, not the inside, but it was still dryinig too fast and it cracked. I'll give this a shot. The plastic should slow it down a great deal more.
>Can these be remounted once they have dried? I use a steady rest as these peices are 15-20 in long and are no longer true. I'm afraid it will beat my steady rest to pieces. What have you folks done?
>Add a ring if you want to use a steady rest on something that isn't solid or round.
I make these from Pine because it is easy to remove if I have to turn it off. They are easier to remove if you use a cellulose glue such as Duco Household cenent or Testors Model Airplane Cement. They are soluble in Acetone or Laquer Thinner, so it is easy to soften and remove. I always use a lacquer sealer, and there is no problem with compatibility. If you use a Titebond or similar glue, you will have to turn it off, and then you will be glad you used Pine to make the ring.
