Hollow form bottom work
Pete in Holland, MI
>Hey all -
Have been playing with the Jamieson-like boring rig that I built last month and have been having some good fun with it. Have made several vase-type things. Wondering though: are the bottoms cleaned up with a similar process to cleaning up bowl bottoms with a vacuum chuck, or are there different means of holding these things?
Thanks !
Pete
Re: Hollow form bottom work
eliot d------WebKitFormBoundaryu+MBDi+0MX0Pf5O9---
>Probably the easiest way is to turn a scrap so it more or less fits over the top of your hollow form. Then hold your piece between it, at the head stock, and the tail stock revolving center. Then clean up your base however you want and, finally, take off the form and just cut off the little nub that's left on the bottom with a sharp chisel. I always use a very sharp, cheap, little curved carving tool only for that purpose. Another way is get hold of a Kone holder. It's basically a rod of metal with a morse taper that goes in the headstock spindle. At the other end there's a small pad. And there's a cone-shaped wooden part that slides along the rod. The idea is to put the rod through the opening in your nearly finished hollow form and slide it all the way to the bottom of the form. Put the morse taper in the headstock spindle and bring up the tailstock live center to squeeze the form between the bottom of your form -- from the inside -- and the revolving center. You also slide the one-shaped wooden part up to the opening in your form for stability. Then you turn away!
>Woops! Word in last sentence should read.'cone' -- not 'one'.
I made one like Eliot said...
Al Neighbors
>Only the cone is made with a tenon to hold in the chuck. The rod has a leather tip glued on, to soften it's approach to the inside bottom.
There is a set screw to allow the rod to clamp the bottom against the tailstock, while the cone fits inside the lip of the hollowform opening.
I've got a pic somewhere, but can't find it right now.
It's called a Kirsten Cone
keith zimmerman, Normal IL
>I made one from plastic and an old pen mandrel. Google Kirsten Cone and you will find plans to make one.
keithz
Re: Hollow form bottom work------WebKitFormBoundar
>Just so you don't think I can't spell,'cone', the Kirsten Kone really is spelled with a k -- not a c. So when you Google it, you'll know.
------WebKitFormBoundaryXKng+MhFJF+ztndh
Chip in Plano
>This is also called a Woodchucker Mandrel sold by a popular woodturning supplier for about $50.
Thanx guys !
Pete in Holland, MI
Re: It's called a Kirsten Cone
Al Neighbors
>Keith, I never can remember what that thing is called. Maybe I ought to label the place they sit, so I'll remember.... :o)
Re: I made one like Eliot said...
Carole Valentine
>I never bothered with a rod. I just use a cone with a square of white rubber shelf liner over it (for drive friction) and bring the tailstock (cup center with small point) up to the nub. I have one of those Kirsten cones someone gave me, but it is a lot more trouble and doesn't work any better.
