>I made this one from half a bolt. Cut a slot down the middle and then cut off the top half. Clean up the threads with a triangular file and then file and polish the flat side. I used a 7/16 x 13 bolt. I drilled a 3/8" hole in the plain end and inserted a 3/8" piece of steel rod. I drilled a small hole in the side and drove a brass nail through to hold them together.
This one works but not as easily as the traditional threader. You have to apply more pressure during the cut. It is much simpler to make however.
>Nice job John! Isn't a 7/16-13 a bastard size? I know 7/16-14 is common and 1/2-13 is common,where did you get that size? Did you chase it? I really like the pin in place idea.
Do you not need relief behind where the thread meets the wood? Keep us updated.pw
>1. Why do you think more pressure is required than on the other cutter designs?
It's probably not more pressure just different since your pushing sideways from the end of the handle rather than straight in like the traditional cutters
2. How do you cut the male threads on the base flange?
I'm not sure what you mean by base flange. On a lidded box with the threads on the lid you have to cut a relief between the threaded portion and the flange of the lid. Then you have to get the tool out of there quickly as it travels toward the flange. This is why you do a sort of oval cutting technique. Push the tool in, cut, pull out, go back to the start and repeat. That's why slow speeds of the lathe are necessary. If you hit that flange the tool cut rings and ruins all your threads.
3. Do you cut the threads with the flat of the cutter up or down against the rest?
The Flat is up. You could file the bottom side flat and it might help orient the cutter better. I didn't because you might have to tilt the cutter angle slightly to find the sweet spot that cuts the cleanest.
>Probably a brain fart error. It is 7/16x14 I did look through the MSC catalog last night and you can buy a tap in just about any thread pitch you want. You could then tap a thicker piece of steel to that thread size and make your own custom jig.
