>Houston, we have vacuum. Got it wired today and it works. Pulled 28 pounds with my finger over the intake. It was not as nosey as my dust collector. Should be better when the filter comes next week.
I have not been doing bowls but you can bet I will have one on the lathe before dark tomorrow.
>Way to go! You know it's not just for bowls...I have put a couple of my smaller hollow forms in there to redo the bottom (VERY gently!)
I spent the afternoon at Lowes putting together the fittings for my adaptor so I can get rid of the HoldFast. Like you, I have ended up with quite a few extra parts that I will return when I am sure what works. Three guys came up and asked if they could help me and I said sure, if you know anything about fittings. "Oh yeah, we can help! What are you doing?" Told them I was a woodturner and was setting up a vacuum adapter for my lathe and showed them a sketch. They all walked away! So much for Lowes customer assistance.
>Norm, I have 4 of hard wood glued up in the shop that I am going to attach to the back of MDF and tap to fit my spindle. I think I am going to use some high tech polyethylene for chucks. I just need to figure what size chucks I need before I order it.
Carole most people have no idea what we wood turners do. I ran into the same thing at the hardware store up the road from me. I took the pump and filters and spent some time sitting in the floor checking out the fittings I needed. I still have a couple extra. The people in the store would come by and just shake their heads. They think I am out of my head.
>Howdy Dick: You can cut the noise down considerably by installing a muffler on the outake port of the pump. I have several chucks of various sizes and shapes. Also, when making a flat chuck, concave it slightly. That way flat turnings will hold better. I've turned plates out of 3/4" stock held by nothing but vacuum. But the chuck must be concave to accomplish that. Watch your pressure and have fun.
>Too bad you don't live around here. This is the type of challange I loved to get from customers before I retired last July. You can't believe the things I helped to rig form standard plumbing and hardware
>That's good news, Dick. I've got the same pump as you (had it sitting around the shop for a few years) and worked with it all day yesterday. Checked for leaks, none found, took the end plate on and off a dozen times trying to make sure the vanes were right (spent a ton of time on the net getting information on this pump) tried everything and could only get the thing to pull 19 inches with my hand covering the spindle.
I sure wish I knew what to do with this pump other than to replace it. Any help from anybody would sure be appreciated.
>Place your guage directly in line with the pump input. Nothing else in the system. Now place your thumb over the line (after the guage) and see what the reading is. That reading is what your pump is providing. Now, slowly hook things up 'till you get a big drop. My experience is many filters pose a problem. Most people use filters intended for fuel, not air.
>Cyril, Just from what I've read on the net 19 inches might be plenty depending on your chuck size. I have the same pump from Surplus Center and it pulls 27 inches. Gast has a vane kit K478A(no seals or bearings ) but that sells for $54.70 according to Industrial Supply in Norfolk, Va. Not too cost effective when a pump from Surplus is $55 plus shipping with a 90 day warranty. You can check the GAST site http://www.gastmfg.com/distribution.html to find the distributor nearest you and see if they have any other ideas.
