Chinese Tallow or Popcorn Tree
Jerry in INdy
>Our neighbor here in Fla is going to cut down a popcorn tree and I was wondering if the wood is something that I might want to save. Does anyone have experience or an opinion?
Thanks
Jerry
Re: Chinese Tallow or Popcorn Tree
Tom Henderson, Gulf Breeze FL
>I got a piece of the trunk from a 18" tree and and made a couple of bowls. It turned very nicely and even had some curl. I have heard that some are sensitive to the dust, but I had no problems.
James McClure
>Most of the time, yes. However, I have had some of this wood that refused to cut cleanly no matter what I tried. I think the difference is how fast the tree grew. This is a nuisance species and spreads like crazy. Normally, it is a small gnarly shade tree, but they can grow straight and tall (and quickly) in the right conditions. The wood that I got that didn't turn very well was the straight and tall variety. Most of the time it cuts like butter though.
It is a strage wood and when wet, it doesn't smell very good. It's pretty easy to dry without cracking. It has a very pecular way of spalting too. I think it is more like a blue stain that actualy spalting. While growing, it is a very light colored wood (almost as white as holly), but it will develop brown streaks quickly after it is cut and eventually turn completely brown.
James McClure
>This was my entry in the AAW Turning Green show a couple of years ago.
James McClure
>This is a mini-sunhat that I made for a donation for a fundraiser recently. The theme of the fundraiser was the Kentucky Derby.
Russ Fairfield
>"turning color quickly" is putting it mildly. It is very difficult to keep the wood "white" unless you turn it within a couple days of when the tree was cut down. Even then, you can watch a fresh piece of nice white wood develop a brown streak that grows bigger as you turn it. Once the wood is dry, the staining stops growing. It dries quickly and without incident.
By all means, have it sent to you. The worst that can happen is that it will be stained as in the photos. The wood still looks good, as you can see from the photos. It will smell like dog poop when you turn it after the stainihng has started. That too goes away when it dries.
This little 6" bowl was turned the same day as the tree was cut down. The yellow color is typical.
Dick Hines
Dick Hines
>Popcorn tree? Now that is my kind of tree. When do you harvest the popcorn and will they live in VA?
