Do you use protection?
Richard Jones
>Thinking of wrapping chuck jaws with some very dense foam so that I can retain as much flesh as possible on my left hand.
What are some others using, if anything? Pics always welcome.
Thanks, and have a great day.
Rich
Re: Do you use protection?
John Jordan
>The tenon/jaw size should be such that the jaws NEVER extend outside the body of the chuck.
John
Bill Howatt
>I try to size the tenon so the jaws stay close to the chuck body. I did buy a "chuck cuff" from LV which is an wide elastic ring that looks like a rainbow. It fits over the chuck/jaw body and does smooth out the big bumps a bit and it is easy to see. But to be honest, I rarely use it unless the jaws are really proud of the body. Sooner or later you do learn!
Bill
Who shouldn't be preaching because he stuck the end of his detail gouge into Stronghold spigot jaws and broke the toolrest.
Philip Morris
>Richard,
Not really sure about your application/setup, but I recently had to cross a similar bridge.
I downsized lathes and the scale of what I turned. I still retained the Oneway Stronghold chuck from the larger lathe, however. I found that using the Stronghold for smaller turnings I was getting closer than I wanted to the chuck. I had a pair of No.1 spigot jaws that moved the work away from the chuck, but to grasp a tenon greater than 1" dia, the jaws extended past the chuck body. Lee Valley sells a cuff to cover the exposed jaws, which I considered.
Instead, I decided to purchase a smaller chuck with No.2 tower jaws. It allows me to keep the jaws within the chuck body, the chuck is smaller so less obtrusive and the work is held away from the chuck.
So to summarize, I chose to design out the hazard, rather than try to work around it. The total cost was about $200, which was cheaper than a visit to the emergency room.
Another comment
Bill Howatt
>I also just try to avoid working near the chuck although my previous comment about my spigot jaws and detail gouge show that it doesn't always happen. If I'm doing a bowl I just try to work at a fairly safe distance from the chuck and deal with the chuck end when I reverse it in my vacuum chuck.
Bill
Nope
keith zimmerman, Normal IL
>I have only been injured once by the jaws on my chuck and that was just a nick. I do get a lot of tickles though. My reaction time must be good enough that I can pull back fast enough to avoid serious damage.
keithz
>Ideally you should have the chuck jaws very nearly closed when gripping something. This gives the maximum amount of surface against the wood to maximize the grip. When you do that the jaws don't stick out.
Of course every now and then either because we are too lazy or just to speed things up. Consequently you end up either touching the jaws or hitting the jaws with a tool. I don't use any kind of protection over the chuck I just try to remember what I'm doing. By the way, Thompson tools don't dull as bad as HSS when cutting the chuck jaws. You don't need to ask how I know that.
Talking About Protection-
Ken Oakley-Sunny St. Cloud, Fla.
>There is a website that shows some pretty gory photos and it has a series of photos showing what happens if you wear loose clothing while working on a lathe. I am not including a link because some people might find the site offensive, but if you would like a link, email me and I will send it to you. You will never again wear long sleeves while turning.
No
Barbara Gill, Remlik VA
Chuck "cuffs"
>Lee Valley sells them - they are just brightly colored cuff which fit around the edges to warn you not to go too closely. If your wife or significant other knits, they can knit you one out of spare sock yarn. It might look funny, but it is a good warning.
Donna Banfield
>I was going to reply "I am way past the age where I need to worry about that, and he got snipped", but then that's not the kind of protection you were talking about. ;^) (And I can't believe I was the only one in this group to think of that)
The only time I ever had to worry about hitting my knuckles is when I am demonstrating on a club lathe and I forgot to bring one of my Vicmarc chucks. The club lathes have Oneway Stronghold or Talon chucks. It doesn't take much before the slides of the jaws are proud of the body, when compared to the Vicmarc. As a general rule, I prefer to keep the jaws very close to nearly shut, because the wider the jaws open up, the more 'oval' they become. Hence, the less likely you have solid contact on the jaws to wood, as was pointed out by several people. But even with the Oneway chucks, it doesn't take many turns of the key for the slides to protrude from the body.
Rich Egan
>Yes, and our second child is due in May!
No, but..
David Belser
>No, and I often work close to the chuck when trying to get one last top out of scrap of exotic wood. My smallest jaws have a number of tool nicks on them. If you keep your fingers on the outside of the tool rest it's pretty hard to get your knuckles close to the chuck body.
But I *DO* have a pair of red socks stapled to a low beam in my wood storage area. Damn near knocked my self out on more than one occasion.
Re: No, but..
Adrien
>I tried using a section of inner tube (from a tire) but the *bleeping thing wouldn't stay on.
>I've run the skew into the chuck jaws, but never my fingers. I don't wrap with anything.
It seems it would be easy to devise a shield that fit over the pointy parts of the chuck if needed. Could be plexiglass or even thin plywood or hardboard.
Re: No, but..
David Belser
>Red socks don't soften the beam any at all, but I usually catch them in my vision as they hang down enough to hit me in the face. That's enough to slow me down and remind me to duck.
More than on visitor has asked "How come your socks are stapled to the ceiling?"
Chuck Engstrom
>Hi all -- first thing I do with a new chuck or jaws is take the jaws and jaw slides off and round off all their exposed edges on the grinder -- see photo, softened on left, factory fresh on right. I can still get bumped plenty hard but I haven't lost any more blood since I started doing this.
Best--
Chuck
bowlman
>I can only echo what John has said. Though maybe I should echo it with a rock 'n roll set of those enormous amps and a huge speakers. This is one of those topics that is way understated. The chuck jaws should NEVER extend so far out that they become a hazard to your digits. Yesterday I submitted an article to the editor of the AAW Journal about chucks. The section on creating a safe and usable tenon or spigot stresses the point about extending the chuck jaws beyond the body. Hope it makes the editorial cutting.
