thin turning help?
thin turning help?
thin turning help?
phil in NJ
>Hi,
Looking for some references (DVDs, etc.) for techniques on thin turning bowls. I typically core bowls wet, then turn them once
dry.
I'm struggling a bit with turning thinner than 3/8" walls on
cherry and walnut... I end up having to do too much sanding with
80-grit, due to vibration.
Are there DVDs I should watch that can help?
Thanks!
Phil
Re: thin turning help?
Doug Thompson near Cleveland
>Phil, one way is to turn 1 inch at a time to thickness and never go back with a gouge.
>Doug has it right. I also concentrate on taking as much pressure as possible off the bevel. On the last 3 or 4 passes to thin it out concentrate on not pushing the the tool forward any faster than it needs to go and lighten up the pressure on the bevel as much as you can. A sharp tool help a lot with both of these.
The best way I know to learn thin turning is to turn square turnings. You need extremely light pressure on the bevel to turn square. It makes a lot of noise. The less noise there is the less the bevel is rubbing so you get an audible indication of how much pressure you are putting on the bevel.
Greg Haugen
>Phil,
JoHannes Michelson's DVD on turning hats is excellent for turning "green wood" thin. His bowl gouge (HannesTool) grind is designed for it. http://hannestool.com
Also Binh Pho has a "thin wall turning" DVD is also excellent.
As Doug mentioned by turning it in "steps" of approx. an inch at a time you're still maintaining the support but not thinning it all at once. Just be sure to finish one area first, and DO NOT GO BACK!
Also if you don't have a "secondary bevel/relief bevel/micro bevel", it will help to have one. As with the HannesTool, the heel of the grind is almost none existent. The pressure from the heel is where a lot of the vibrations come from. Simply "shorten" the bevel by grinding the heel back so that back edge isn't rubbing. Also, make sure you have a good solid chuck jaw to tenon connection.
Have fun,
Greg H.
Dick Coers
>You've got some nice pointers, here's a couple more. On bowl work, you can use your hand as a vibration dampener. I use the thumb on my left hand as a fulcrum for the gouge, but also have my fingers ride on the outside of the bowl to dampen vibration. Gentle is the key word as the definition of friction can be quickly defined in this process. The other technique is to introduce a liquid to the wood to soften the fiber for a shallow cut. I've seen or heard of many materials, from water to sanding sealer, to shaving cream. The goal here is just to soften the fibers, then cut them off. I also use water to "whisker" before the final sanding on cherry and walnut. The dampness here will swell any fiber (and sometimes fine sanding scratches) that did not get cut off with the abrasive. It then cuts off very nicely with 320 grit.
Del Stubbs had the first video on turning thin. It's a classic.
robo hippy
>I turn green to final thickness, and let them dry and warp also. Most of my bowls are between 1/4 and 1/2 inch thick. The bigger the bowl, the more rim problems you are going to have because the wood will adjust and move due to having bulk/mass removed from the center. Add to that that it is drying and warping, and the problem gets to be larger. Add again to this that you have removed a lot of the mass that keeps the wood stable and vibration free, and you have more problems. Think of a soap bubble. Left to itself, it stays round, but any slight breeze will make it deform and vibrate. These problems can be delt with.
Some people will use a steady rest. I don't, mostly because I learned to do without it, and also, it would be an extra step for each bowl I do. Since the bowl has been cored, you will be thin at the top of the bowl already. You can use your hand as a steady rest. First thing to do is round over the rim of the bowl first, don't leave it square. If you haven't found this out the hard way, that edge is like a razor saw, and will slice your hand up. Use gentle pressure: if your hand is getting hot, you are pressing too hard. Hand pressure should be the same as your gouge or scraper pressure. You can push too hard, and make the bowl rim wobble/oscilate more to the point that you get a big catch, and explosion. As said before, turn to final thickness an inch or two at a time, then proceed another inch or two, and repeat as necessary all the way to the bottom. A VERY light touch is required some times, and a sharp gouge, or shear cut with a scraper (at 45 degrees) can do excellent touch up. Never use your scraper flat as that pulls the fibers more, and is better suited for a roughing cut than a finish cut. It also involves more pressure for the cut = more vibration = catches = explosion.
Another note. For the thin turned bowls, the DNA (alcohol) or LDD (soap) soaks do nothing to speed drying time or prevent movement or cracking. I make this statement based on drying several hundred bowls with the DNA soak, a thousand or so just air dried, and several thousand LDD soaked. I even did a side by side test of the 3 methods and weighed them every day till they were dry. No measurable or observable differences. The LDD does help the bowls sand out a lot easier. There could be differences on thich turned bowls, but I have never tried that method. To dry the bowls, wrap a couple of layers of newspaper around the outside of the bowl, then secure it to the rim with some or the 6 inch stretch plastic film that you wrap around boxes. Wrap around the rim a couple of times, leaving an inch or so of overhang on the inside to cover the rim. Stretch the plastic to put some pressure on the rim. Cut out the paper on the inside of the bowl. This has done more to prevent cracks than anything I have tried to date.
There is a similar post on the AAW site about finishing the inside of a bowl.
robo hippy
Brad Vietje
Brad Vietje
>If you shorten the bevel, you can also smooth or polish the edge that results where the bevels meet, so it won't bruise/pull the fibers as much.
Safe spinning,
Brad Vietje
Newbury, VT
Brad Vietje
I'm with Robo...
Brad Vietje
>I'll add, though, that when shear scraping the individual "steps" as you work your way down into the bowl, be very careful about the unsupported (raised) edge of the scraper hitting the thicker part adjacent to the part you're working on -- in other words, the next step down into the bowl. If that edge touches, you can get a mighty fearsome catch.
Safe spinning,
Brad Vietje
Newbury, VT
What is a "square turning"?
Adrien
Re: What is a "square turning"?
Ron Solfest
>I think he's refering to tall, straight sides (no curve).
turning square pieces
>What I was referring to is turning pieces that are square or rectangular. You have what we call an interrupted cut or some call it turning air. When you are turning the outside edges the tool hits the wood 4 times with a gap in between. It makes a lot of noise and requires a delicate touch of the bevel to get it right. I think it's excellent practice because you can tell how hard you are pushing against the bevel by the noise. I try to make it as quiet as I can and guess what, the cuts improve and your skills improve.
This is excellent practice for turning natural edge bowls or any piece that has voids. I used to start all of my hand mirrors from square boards. These corners were cut off to make the mirror round but I used these corners as practice for turning pieces that had voids. It was well worth it.
George Van Beynen
>Phil, you have been given great advice. Trent Bosch once told me that a light touch with a gouge was similar to a butterfly landing on a flower, I use this thought daily.
Re: Here's a square turning.
Jamie D
I knew Jamie would jump on this one :)
Russ Fairfield
>I am surpeized that nobody has mentioned the alternative (or did I miss it) of turning the outside last to achieve the final thickness.
If you were to turn the wood to the same 3/8" thickness, and it was UNIFORM all the way down the depth of the piece, you could then take a 1/8" cut off the outside and you would have a 1/8" thickness. Then take another 1/16", and it will be getting really thin. An advantage of this is that you can better see what you are doing. You can also make a plug for the open rim and bring up the tailstock for support. This support has the advantage of putting the wood in compression so there is less or no vibration, and the wood will stay round.
For the skeptics, it doesn't take any greater degree of tool control than trying to turn to 1/8" or less thickness from the inside. I would argue that it would require less because you can see exactly how much wood is being removed throughout the cut, and you are doing it with a shearing cut that puts less stress on the wood and leaves a smoother surface.
One of the problems with hollowing green wood to thin is that it starts to dry and doesn't stay round. This can be the limiting factor to wall thickness. Keeping a spray bottle of water handy and keeping the wood wet will help, whether you turn it to thin from the inside or the outside.
Don't forget to leave an allowance for sanding. This can be as much as 1/16" in the softer woods. And beware of soft spots in spalted wood where it is easy to sand through the thin wall. Also be aware that the flat grain areas in what is otherwise solid wood can also sand away more easilly.
Another hint to keeping a really thin piece round as it dries. Spin it in the lathe for overnight or however long it takes to dry. 400-600 RPM seems to work best for most pieces in the 12" diameter. The spinning will insure a more uniform drying rate, and the centrifugal forces will help to keep it rounder than it would be if it had dryed while sitting on a shelf. Putting a fan near the spinning piece will keep the air moving, and a 100-watt light bulb helps in a cold shop.
If you are drying it on the shelf and the piece is a bowl, set it rim down on several thickness of wet newspaper or paper towel. Left to itself, the rim will dry faster than the rest of the bowl, and small cracks around the rim can ruin a nice bowl. The wet paper will make the rim dry last and there will be no cracking.
I always have to ask the question - Why thin?? Depending on what the piece will be used for, there is nothing wrong with a 3/8" wall thickness. Nobody but another woodturner likes thin walls on a salad bowl. People who use them prefer thickness and weight, and 3/8" or even 1/2" is desireable. The thin ones become "art" because they aren't very useable for anything other than being something to look at.
Re:Hey Russ, check your math on thickness!
Jamie D
Russ Fairfield
>Yup, you will have 1/4" of wood to take off, not 1/8".
