Re: Bearing for a vac adaptor
mfoster
>Well this is a timely topic for me. I've been reworking my rotary adapter. I used to pull about 20 in of hg with an older adapter that I made which finally failed (rubber seals failed). I have tried to duplicate my previous efforts with several bearings, but none have been able to get more than 10 in of hg for me. It has been rather frustrating. I have absolutely isolated the vacuum leak to the bearings. My most recent thoughts for fixing the leaks was to find a really thick grease but now i think I may give another go at two double sealed bearings. My latest iteration was to use the double shielded bearings, which leaked like a sieve (3 in of hg). I was thinking they may last longer than the rubber seals, bad idea.
I use a design someone came up with (not me but I can't remember who) that allows you to keep the adapter on the handwheel. Just remove the vacuum hose and I can use a knock out bar to remove MT drives. If I get a decent vacuum running, I'll post pics of my version.
Mike
