Drying Bowls
Drying Bowls
Drying Bowls
Jim Hoeller------WebKitFormBoundarycQB+IfmNjFaVxeA
>I have read articles that mention using a microwave oven to dry bowls before final turning. I've not been able to locate any of them and hope someone can advise me. I would like to turn a green bowl to about an inch or so, dry it and then finish it. If my understanding of the process is correct, the microwave will eliminate the year or so it would take to air dry.
Thanks
Re: Drying Bowls
Re: Drying Bowls
bill Crommett
>Jim: A microwave will do a good job of drying bowls, but it does have its' downside. It can dry the wood too fast and thus cause cracking, burning, case hardening and smoke. So if you do not have a dedicated microwave for your shop be extra careful if you want to live peacefully in the same house with a person who doesn't like all foods to smell like burned wood.
I have a small dedicated microwave that I have covered up most of the out-vents to keep a good percentage of moisture in the cabinet -- just like a commercial kiln. This keeps the moisture almost even through the thickness of the wood so it doesn't case-harden and leave lots of extra stress to be removed when you finish turning the piece.
Start easy and feel your way.
Re: Drying Bowls
Dennis in Southern Oregon
Re: Drying Bowls
>Jim, have you considered using alcohol as a drying aid? It will reduce the drying time for a rough-turned bowl from several months to less that a month in most cases. A search in the archives probably will find many references to this. Here is a capsule description of the process:
Get a lidded container large enough to hold the bowl. (I use 5-gal plastic paint buckets.) Buy a gallon or so of alcohol from your local Ace hardware. Submerge your bowl in alcohol in the lidded container for 1 to 2 days. (More won't hurt but is not needed.) Remove the bowl and allow it to dry until it reaches a stable weight. I use a $35.00 electronic postal scale from Staples to check the weight. If the species of wood is prone to cracking, wrap the outside of the bowl in paper so that the inside dries faster. The alcohol can be reused several times. Although the used alcohol looks as that though it might stain new wood, it never seems to do so.
Dennis
Re: Drying Bowls
Re: Drying Bowls
Jim Sebring
>How does one keep a wood bowl submerged in the alcohol? Would a lead bar work ok(I have about 50 lbs. in one lb. bars), or would it stain the wood?
Re: Drying Bowls
Denatured Alcohol Drying *LINK*
Barbara Gill, Remlik VA
>If you are going to use the denatured alcohol drying method I would suggest getting your information from Dave Smith's article. He is the one who developed it.
Alcohol Drying Method for Bowls
Re: Drying Bowls
Re: Drying Bowls  *LINK*
Another Simple Search
Re: Drying Bowls
Rob Wallace
Re: Drying Bowls
Rob Wallace
>Jim:
I use inexpensive large hardware (1" or 1.5" bolts, nuts, and washers) purchased from the local farm supply store when they have their "bag sale", and all Grade 2 hardware is $1.20 per pound. I've never had any problems with rusting or transfer of any "color" to the piece soaking in alcohol, at least for the past several years I've been doing alcohol soaking. The hardware is available in convenient sizes and shapes (your choice); for example, several large washers can be stacked in a bowl to keep it submerged, or a few nuts or bolts can be placed inside a hollow form. This is a cheap and safe way of getting the job done.
Lead bars would work, I suppose, but I prefer to avoid continual body contact with any form of lead if I have a choice. As laboratory scientists, we receive mandatory training from the University's Environmental Health and Safety folks about limiting body exposure to many chemical materials, and the heavy metals are among them (in any form: salts, oxides, etc. or as 'pure' or alloyed metals) which includes lead. I suggest using the lead you have to weigh down your lathe, and get some more benign, dense, heavy materials to weigh-down your turned items during alcohol soaking. Lead is among the more insidious materials that does not "interact well" with living organisms.......
Rob Wallace
Re: Drying Bowls
Rob Wallace
Rob Wallace
>Jim:
Have a look at some of the sites available at the following link to learn more about green wood processing and drying bowls - lots of information on this topic...
Rob Wallace
Processing of Green Wood Links
Re: Drying Bowls
Re: Drying Bowls
MFoster
>Just FYI. Microwave drying can be dangerous. I used to live in Southern CO and went to buy some wood from a local craftsman that made really nice funeral urns (not turned), but got into the buisiness of reselling wood as well. He had a shop to die for with serveral bandsaws, and lots of large equipment capable of handling 8 ft diam. logs and burls from the west coast. He also was a volunteer fireman. He was microwave drying some wood, and got called for a fire (this was real rural southwest CO). In the midst of fighting the fire, they got called for another fire. Yep, in a rush he forgot to turn off the microwave, and his shop burned to the ground. He lost everything, luckily he had insurance and was able to replace it. Just a word of warning.
Mike
Re: Drying Bowls
Dick Hines
Re: Drying Bowls
Dick Hines
>If the wood was turned wet it will sink. I have been useing DNA for a few years and having great success.
Re: Drying Bowls
Re: Drying Bowls
Walter Cullop
>I recently started using the alcohol method and it does a great job. There are many articles about it on the web.
Re: Drying Bowls
John Jordan
>I would suggest spending the time it takes it to dry turning more. It's much simpler that way, and practice is the only way you will learn. Microwaves and alcohol aren't really needed, as is often the case simple is good.
A roughed out bowl will dry in as little as 6 weeks. I've included a link that may help.
John
Using green wood
Re: Drying Bowls
works for me
robert davis
>i have a dedicated microwave in shop..this works for me. first weigh bowl.. bowl is dry when it ceases to lose weight..wrap in big towel micro at defrost setting for 20 seconds.let cool in towel. new towel repeat till no weight loss.
